wearetheromans85
80 gallon 5hp 220v air comp or 30 gallon 2hp 110v air comp? I'm debating on which to buy.
It's not how much 'electricity' a compressor uses, its how much energy out you get for energy in. What are you really asking here? Are you concerened about operating costs, circuit requirements to install, or something else? Electricity is not a measurable item. You have to think in terms of current or power.
lg
no neat sig line
Sure it is, voltage.
No it is not. Electricity is a common term, not scaleable. It is like saying 'Fuel', it in not a scaleable term. Voltage is a measurable component of electricity but it alone does not make up electricity. In the Op the guy asked about a 220v compressor vs a 110v compressor. But that is not the whole equation. If both compressors were the same HP would you say that 110v unit would still use less electricity?
lg
no neat sig line
Amps is the measure of rate of flow, watts would = power.
The power company uses Kilo watts per hour to measure electric consumption, so yes, it is very much "measurable".
The OP was asking about "consumption", so its readily apparent his concern was energy consumption.
Charles
