Which cut off tool?
hknladdr
SoCal
I need to cut a couple sections of tubing out of a roll cage and then smooth out the welds. Which tool would be best to buy, 4 1/2 electric angle grinder or air die grinder/cut off tool? Thanks.
epmills
Missouri
If you're cutting and smoothing, I would say the angle grinder. I have used my cheap HF for just that purpose before, and it worked great. If the roll cage is already in the car, a die grinder with a cutoff tool may be better due to the space constraints (just be carefull, no guard with a die grinder!), then you could switch to a different bit for smoothing.
garfunkle24
Saskatoon, Canada
The die grinder will be much better in tight spots but the electric grinder will make shorter work of the cuts. Also, I prefer a regular die grinder to a cut-off tool as that guard does limit access somewhat. I die grinder is also much more versatile, and would allow you to use a carbide burr or some other means of grinding the welds as well as cut the tubes. Of course the electric grinder will do both also.
garfunkle24
Saskatoon, Canada
epmills, you posted while I was typing, but I see we're on the same page.
Also, I forgot to mention that die grinders are air hogs and you will need a half decent compressor to keep up with one if you're working it hard. Don't know if this is a consideration, but thought it might be.
kvom
*******, GA
Neither is very expensive. Get the angle grinder to cut and the die grinder to smooth.
That said, the angle grinder is IMO a more versatile tool for any future needs.
eschoendorff
I agree. I have several of the cheap orange HF angle grinders and they do a lot of things reasonably well. They are inexpensive and convenient - no air hoses.
billymade
New Mexico
I love my florida pneumatic die grinder and they are reasonabley priced too!
http://www.sjdiscounttools.com/manufacturers-florida-pneumatic-mfg.html
sjdiscounttools_2009_82831533
sjdiscounttools_2009_85137428
sjdiscounttools_2013_374492502
sjdiscounttools_2009_83048619
sjdiscounttools_2009_82931391
