Brentocool
I always see them the wrong way!! So what do you think?
Hack saws are meant to cut on the push stroke. Pointy part points forward.
Saws that cut on the pull stroke do not require a frame or spine. Totally different kind of saw.
Powered saws on the pull stroke, .
^^^+1Depends upon what you are cutting. Normally, cut on the push stroke on plate and all, but I reverse the blade with teeth pointing toward me when I cut pipe, especially sheet metal. It just makes it a lot easier.
Only if cutting downward.14 posts and nobody has pointed out that the teeth are supposed to point down!![]()
^^^+1
-Depends on the application. I run my hacksaw both ways. Normally when I pick it up I check which direction the teeth are going so I know what type of motion to use. If the teeth are wrong for the application I reverse the blade.
With those little blade holders for tight spaces I almost always use the teeth pointing towards me so I cut with the pull.
Frank is correct on conventions.
The handle usually works just as well for pulling. I have also just turned the saw around occasionally for a quick job. I usually prefer to pull if I can since there are fewer chances for injuries when pulling away from the work.The hacksaw handle is designed to give you a good surface for your palm to push with. When I need a pull stroke (some lathe operations come to mind), I just turn the saw around. I never bother with reversing the blade.
In the west push. European.
In the east pull. Japanese.
In all cutting aspects.
Not with a coping saw.
Why use a hacksaw when you can use a chainsaw....I think Tim Taylor said that?
I have yet to find a metal cutting blade for my chainsaw.
There is an untapped market there I think....
for cutting pvc and abs it works better when the blade is backwards
The Japanese use a small knife (Dsouki) that pulls through the wood. I have one.
Dōzuki — a Japanese backsaw, used for centuries by carpenters and cabinetmakers in Japan. Although this saw does not share an ancestry with the other backsaws in this group, the concept is the same. Like most Japanese saws, the dōzuki cuts on the pull stroke, allowing for much straighter and narrower cuts than those achieved with push-stroke saws. This is due to tension on the blade during the cut (versus compression for a western saw), so less thickness is required to keep the saw blade straight.
Absolutely the best way to use the tool on metal. Blades last for a long time. Cut slowly and deliberately.All I remember is CWO Bussi constantly getting on my case for not lifting the hacksaw off the work every time, bringing it back toward me, placing it on the work, and pushing the hacksaw through the metal. Traumatized.
There should be an arrow on the blade.
Yes, and surprisingly you end up cutting the piece more quickly because you don't damage the teeth dragging them back across the work or cutting too fast.
