Which drill press would you keep
tool_scrounge
Southern California
The other problem with the Homecrafts are bushings, rather than bearings, in the quill. I understand the trick setup is to swap in a DP 220 spindle, though I haven't actually done it myself.
Really tough call on the Powermatic/Delta thing. I've never used a Powermatic Reeves drive, but was never really impressed with the others, including Delta's that I have used. The table raiser is pretty much a must have for me. On the other hand, that is probably one of the best Delta 15" DP's ever made, with 6 speeds, and 6" of quill travel. Decisions, decisions......
Sleeve bearing upper quill only from the exploded view diagram I saw. It is a lot heavier drill press than I was expecting. Best thing I did was to replace the included laundry machine motor.with a.1140rpm baldor. It reduces the minimum speed from 700 to 470 rpm.
The Delta 6+6 is one of my favorite 15" drill presses. They did make a factory option large size production table with a lifting mechanism like the 17" drill press. By some miracle i ran into a NOS one a while back but I have yet to install it.
lis2323
I also want to know this.
I still think the WORST thing about homecrafts is there is no place for a on/off switch really, so every single one is either a regular 110 switch mounted to the cabinet or macguyver'd off the motor mount. Not that it's not a fine spot for the switch to be, but the boring *** normal switch ***** compared to say, a Cutler-Hammer like my Rockwell has. :)
I use these paddle switches on all my older machines. I realize restoration purists will cringe, but for safety and function this works for me.
u3b3rg33k
Since this looks like the place to ask - i've got an old Atlas press and I think the SKF bearings (so named on the nameplate) are getting tired. is there a good place to ID them and source replacements?
Davefr
OR
Just look for a number stamped on the bearing and either google it or do an Ebay search.
...or go to vintagemachinery.org and see if you can find a parts list for your model machine and find the bearing number.
As a last resort, get out your calipers and measure the key dimensions and hope you can find a match.
This site has some pretty good data:
http://www.skf.com/binary/79-66347/457013.pdf
The guys over at owwm.org can usually help with bearing p/n's for most of the common vintage machines.
Cypherian
Delaware
I kind of want to reclaim space and while the footprint is small i have a hard time justifying two.
The pm 1150a is from 1993 but suffered some neglect and a fire.
The rockwell 15-665 is from 1973 and was unprofessionally refinished by me.
Deltas in features include:
Pm is reeves drives and more truly variable. Rockwell is a belt change
I have a yet unused mortise kit for the rockwell
The pm has the table adjustment and a cleeeean table
The rockwell table has a few holes as its from a school.
What say yall?
While the cool factor goes to the Delta , the ease of speed changes on the Powermatic seems like the better choice. Time to redo it and then get rid of the Delta :}
Cypher
