clonestocker
- Joined
- Jan 9, 2018
- Messages
- 41
I going to be putting a 200 amp service on my new garage. What would be the best panel to use? Will be an overhead in and power out the bottom for a sub-panel on the main house. thanks matt
Vote here for Siemens...which I'm surprised isn't mentioned. Have two Siemens panels in my house and they're quite pleasant to work with, tons of space and the ability to get space saving half sized breakers to increase capacity, no issues with breakers.
My friend had to sell a house he inherited that had a FPE panel. The inspector caught it. I told him to knock $1000 off the price in order to get rid of the house quickly.
How many circuits do you anticipate having in the garage? Is a 200amp panel even necessary?
Better answers will be in the Lighting/ Electric subforum...
Most there in the know will suggest Square D QO, or Cutler Hammer.
Marc
Yeah, either match what you have or get what is easiest to find breakers for. Probably GE or Square D
Exactly.Installing more capacity in the beginning is always better than needing to add capacity later.
When I had the service panel in my house upgraded about 35 years ago a friend who worked in the electrical field recommended a 200 amp 40 space panel at a time when 100 amp panels were pretty much standard in homes.
The electrician I hired to do the install said it was way overkill as I didn't have an electric stove, dryer, water heater or furnace, all those appliances were gas. I insisted that was what I wanted so that's what he put in. Guess what? I may not be using all the capacity of that panel but 38 of the 40 spaces are now filled.
By the way it's a Square D panel and has never given me any reason to regret using that brand.
You would think if this really meant a pinch of **** every other house would be out of power.
