According to the calculator I used, I can use either a Modine HD30 gas heater or the Modine Electromode EUH10B34CT 10/7.5 KW, 240/208 volts, 1 phase at 49 amps electric. With gas in my area at a cost of 7.67 MCF and electricity at .06 cents per KWhr, which is the least expensive to operate figuring I'm in Ohio on Lake Erie? I would like to keep the garage at 40-45 degrees and bump it up 10 degrees when I am working out there. Temperatures are to erratic to figure a constant as it varies sometimes by 30 degrees from early morning to the next evening.
Thanks in advance for any assistance
