Which light? Milwaukee Fuel M18 2.0 battery?
Jacobson
Since I have the battery from my impact wrench, I want to get a light.
But they always seem really expensive, and way more than a dedicated light.
Lantern? Stick light? Work light?
What is the difference?
Which one should I get for car work in a dark garage?
2735-20
http://www.milwaukeetool.com/power-tools/cordless/2735-20
2363-20
http://www.milwaukeetool.com/power-tools/cordless/2363-20
2352-20
http://www.milwaukeetool.com/power-tools/cordless/2352-20
Ign
Butte Peak ND
Stick light probably. I'm presently lying under a trailer wiring up brakes w my M12 stick light, but the optional magnet is a MUST (search the board for Amazon generic magnet, a couple bucks).
Fuel is brushless motors in the tools, so your light won't be Fuel :D
J
Jacobson
I think I could use a general lantern to light up the entire room.
Seems to work great. Thanks for the video link.
BK13
PDX, OR
Dang, that's *********, surfing GJ while underneath a trailer!
stonesfan68
Houston, TX
I think that which light you get is dependent on what you want to do with the the light. I have the 2735-20 and find it very good for lighting up a small work area, like under a sink or lighting up an alternator under the hood. It is a great light.
kramarj
Durand, IL
If you want to light up a whole room, the hexagonal work light is the way to go.
Very good light. From time to time we end up working in a dark garage/storage unit, and it really lights it up. They are also supposedly very tough, when we bought it they were bragging it up how you could kick it across the room or throw it at the wall or something like that.
Strouty
Southern Maine
I vote one or two of each.
I have the lantern and the hexagonal work light. They both work very well and they both ****. As others have said, it depends on what you are doing.
One pet peeve about the lantern is that the switch is a three step one. I wish they had one switch for off and on and another to change the intensity. It is really annoying when you just want to turn it off, but you need to keep clicking the button.
kctyphoon
Jersey/Staten Island
i have a version of all you posted. if you just want one, id go with the m18 stick light - IMO thats the best compromise of everything..
the m18 pistol grip led light is a spot light (i have 2 of them) - on/off only, and it does not light up a big area, and many people dont know that there is a flip out plastic hook in the rear of the handle.. its good for some things - but your not hanging that light under the hood of your car as a work light. its basically a pistol grip flashlight.
the lantern - (i have the m12) is a good general area light, 4 settings, hi, med, low, strobe. but the light is made to be dispursed over a large as area as possible, like a lantern.... so you can light up an entire room over a 360 degree angle down to a 180 degree plane and anything in between.. good if your working in a large room or prepping for power outages or camiping. the limitation is not being able to direct the light upwards or downwards if you need it- and in that case your gonna have to lay it on its side. it has a hook to hang from a nail, or a peice of wire. your best postion of this will be using it at table height as a work light, in a room.. id imagine this would also be a good choice if you work in confined areas, or as an electrician to work over an entire wall or two in a room.
the m18 stick light (i have this too) is the best mix of everything. it gives you a very wide area flood light, ( there are no light/dark areas. the light it very even) 2 light settings, hi/low, indexible head movement up or down, and also gives you two METAL hooks to hand it from.. one on the top of the head, and a sliding hook on the handle that will let you hang the light to be used as a down light ( hang it under your hood) that will adjust to balance the weight no matter what battery size you use.. it is the most versatile of the what you posted, and the most usefull of the 3. it has the same light fixtures as the m12 stick light (i have that TOO), but gives you more light output, longer rutime (i think) and the adjustable head.. if i could only keep one, thats what id keep.
that hex light is a good light from what ive seen - (i dont have that yet) but thats really made to be a cordless light for a jobsite indoors or outside.. think replacement for a halogen light stand ..you can hang it from wire, or make an improvised stand from emt or pvc.. IMO bigger isnt always better for some stuff unless you need it. gonna hard to work behind the tv with one of those, and even more cumbersome to hang to work under your hood.. its an "entire area" light - not so much a directional work light..
lastly - if you have a dark garage (as in NO lights) and access to a power source, your first order of business should be some 4' light fixtures.. costco has some nice led's for sale in the store. if you dont have power, or cant improve the lighting for some reason then that hex light, AND the m18 stick light might be a good item in your shopping cart..
J
Jacobson
I want a general "entire area" light.
Do I get the Hex light or lantern ??
GSteg
Earth
The hex light won't give you 360 degrees of lighting, but it has enough flood that it'll light up a reasonably sized room. It'll just be more concentrated in one area than the other, but that might be all you need. The lantern looks good, but it doesn't seem to have the kind of light output the hex light has.
Ign
Butte Peak ND
This. And/or I still think it should start on low progress to high. Think about dimmer switches and motor speed controls (eg ceiling fans) - they start low and climb. edit: I take that back, maybe speed controls start full and decrease the more you rotate the knob?
I almost bought the hex flood on the last Zoro sale, but didn't.
Anarius
I agree this light is awesome. And yes...it is very tough. I had wedged it on top of a steel rafter at work to do some work on a wall fan, and it fell about 18' to the hard concrete below. The battery ejected and went zooming off, and I went "Aw, ****!".
Other than some scuff marks, it is just fine. And the battery too!
cagullett1
North Texas
I have the M12 stick light, m18 lantern, and m18 flashlight (the first one you pictured). I'm happy with all of them and would not get rid of any. M12 stick is my most used, I purchased a second one. One keeps a flexible arm with magnet on it, and other is plain. Love the flexible arm and magnet.
rlitman
Long Island
Or you point it up at the ceiling and light the room evenly through reflection. The hex is a replacement for a halogen work light (if you're familiar with that beam pattern). It's somewhere between the light output of a 250W and 500W halogen, but it doesn't get hot, and its cordless. Sliced bread, eat your heart out!
I was most recently using it when painting a room. It's great to use from a low angle to bring out imperfections so you can roll over them before they dry.
Working under the car at night, I just point it in the general direction I want, and it's instantly daytime. I'll still bring in a drop light to eliminate shadows and get in tight spaces, but I think the only good match for that is the M12 stick light (which I don't have, but I've got too many corded drop lights within reach to switch any time soon).
J
Jacobson
The Lantern is AWESOME. Blows away my LED light stick and head lamp.
