catalytic
I've decided it's time to upgrade to a decent dial indicator base. I plan on buying a NOGA, unless someone knows of a nice swiss model that can be had at ~NOGA prices. The question is, which model do you recommend?
My only stipulation is that I want the fine adjustment to be on the base. It would also be great if the knobs were metal and not plastic -- I have heard that NOGA either has switched back and forth between metal and plastic, or different models use different materials. Does anyone know?
Finally I would also appreciate any suggestions for where to purchase it (Enco?). Actually, if you have a good suggestion for a dial test indicator to go with it, I may grab a new one of those as well. I was tentatively planning to get a swiss Interapid or Bestest. I don't really need to read tenths -- I don't usually work to precision higher than 0.001"
