Which set of go jacks?
zkdiesel
chicagoland cornfields
6313 convential style heavy duty ones?
Or the suv 7016 with the fancy rollers?
Conventional style advertises 4” and 5” casters. Can’t find what the 7016 is
Need them to stack 3/4 ton trucks in winter nose to but in a building that barealy fits two crew cab long bed end to end. So basically need to gojack the second truck in straight sideways for winter storage.
I want ones that roll the best
Average size 32” tall tire under 12” wide
My two place sled trailer with the single axle with golf cart sized tires may also need to be pushed sideways in. Do either of these models go small enough for that?
Anybody have experience with both sets? Or the new style?
Center door on a 47’ deep buIdling makes
It so you can’t easily stack two **** to nose on either sides
Pictured is the 7016. Takes wider tires but not sure on caster diameter08E8C350-1400-4CD3-AC41-568DC0609B85.jpeg988F8057-B8E3-4E2B-B304-915090FDEA5F.jpeg
kbuhagiar
Escondido, CA
ZKD,
I have a set of four of the 6313s, their rated capacity is 6000lbs.
They appear to have exactly the same casters as the 7016 (which you have pictured).
I have used my 6313s to move a 2004 Chevy Silverado 1500 Z71 Extended Cab, just once. It worked fine but I'm sure I was at the GVW limit. Pretty sure you will need the 7016s for the added capacity.
Z
zkdiesel
Well I picked the 7016. Shoved them under steer tire of my 11500 2wd F350 dually service truck yesturday and they pumped well
Today I dragged on a hydraulically dead skidsteer. Dragged it off with another machine and said wtf, lets go. Easily around the tire, jacked kinda hard but did it. Probably 2750 lbs on each rear tire as with no attachments new Holland’s are really *** axle heavy.
Spun machine 180 into corner with boom up with no issues 40A70D37-0035-4B0D-A14C-F0450F5C26C2.jpeg8968A638-85AB-4AA9-AB7A-7680752BD9E9.jpegEC600439-5634-423B-B663-AF30E3DE410A.jpegFE872ACA-AC14-463E-B403-AF092CA810B7.jpeg9FEE374F-9E9B-46AA-AB34-3B8EF05D9229.jpeg
