I have some questions about piston ring compressors. I'm rebuilding an automotive engine for the first time - I've only ever done motorcycles in the past. The engine I'm working on is from a 1976 Ford Courier - which was actually build by Mazda. It has the Mazda "VB" 1.8l, 8v engine, with a bore and stroke of 78.00mmx96.00mm.
I figured - why cheap out on the ring compressor? Might as well order one of those fixed-size versions. e.g.:
However, I can't find one in exactly the size I need. I'm not sure "close" is good enough in a tool like this.
The issue is this: all four cylinders have a ring ridge on the exhaust side only. I need to have them bored. Pistons and rings are both pretty scarce, but I eventually found and purchased some 0.75mm oversized. According to the information on the side of the box, I need a finished bore size of 3.1003".
In the fixed-style compressors, the closest I've found is 78mm (3.0709") - would my oversized pistons and rings even fit in that?
I saw this slightly-adjustable style from Summit is available in 3.1-3.25":
It's not too bad at $29 USD - but shipping is about $31 to me in Canada, which feels a bit silly. Nevertheless, if that's what I should buy, then that's what I'll get.
Otherwise, I've heard reasonably good things about the "wrinkle band" style compressors. The Lisle is easy to find available locally for ~$25 Canadian.
That seems fine - but I'd rather spend the extra money if the wrinkle band is likely to give me any trouble.
