Which Thread chaser kit?
Matt M PA
SE PA
I've had the Craftsman kit for many years....looks to be the same as Snap-On....works well.
Richard Cranium
central Washington
Back a couple of years ago, this was asked and Craftsman was what every one was saying, plus they were on sale at the time. If you look at the craftsman set, you will see that most are the very same set only with another brand on them.
LB-1911
Northwestern Il.
The 48pc Master Rethreading Kit avaialble from Sears is the same as
- Kastar 971, Snap-On RTD48, MAC TRCOMBO-48
Looking for thread chaser/restorer set
http://www.garagejournal.com/forum/showthread.php?t=87237
The OEM is Kaster/Lang.
Craftsman 48 pc. SAE & Metric Thread Restorer Kit
http://www.sears.com/craftsman-48-pc-sae-metric-thread-restorer-kit/p-00942275000P
48pc SAE & Metric Thread Restorer Kit
http://www.tooldiscounter.com/ItemD...HOdw95-5sf3yXn0ZwEXuwJTKfOaTJoR9txhoCxz_w_wcB
The Truck Tool Equivalents Thread 2.0 - Expanded with Part Numbers
http://www.garagejournal.com/forum/showthread.php?t=249851
CrashmanS
I have the snap on set. But the sears one seems to be the same kit.
Sent from my SM-N920P using Tapatalk
Richard Cranium
central Washington
But with snap on, if you brake or wear out, they have parts available, Sears don't.
But nothing says you couldn't replace broken or worn out parts on your Sears kit with snap on parts.
scooternut
Pittsburgh, PA
Same goes with either kit. I own the Craftsman kit, and when I broke a piece, I just ordered up a fresh one from snap on which was delivered in a few days for just a few bucks. Price was reasonable to fix the set as I recall. The kit is the same, I'm sure I couldn't even pick out the replacement piece.
disston
Silver Spring, Md
Thread chasers are not the same thing as thread cutters. Most all the threading tools are thread cutters. I had a Craftsman set 40 years ago that I used to chase threads in the carb mounting holes of an intake manifold. The threads were thereafter loose. Not a big deal in this application but I never used those bits again because of this.
Google thread chasers.
https://www.amazon.com/s/?ie=UTF8&k...vqmt=p&hvbmt=p&hvdev=c&ref=pd_sl_34dobyrkww_p
ecotec
The Lang/Kastar/Craftsman/Snap-on/Matco set is the best deal. You can usually find the 48pc online for around $50-$55.
J
jgelack
Thanks guys! I just placed an order for the Craftsman 48 pc kit. Thanks again.
6PTsocket
This is trick question. They are virtually all made by Lang, formerly Kastar. The best place to buy it is where you get the lowest price.
J
jgelack
Yep, I got it from Sears, $54 with free shipping. That was the best price I could find.
T45
Kastar and JawCo are not the same, and there are many re-threading die sets made by tap and die makers, so just for accuracy its important to note this.
However, for a general recommendation, I'd say you are right and to go with CMAN on sale...replace with snap-on as needed etc.
Both of those are made by Kastar and are interchangeble. They are all for good reason popular--the balance of functionality/cost and readily available without truck tool premium via sears channels.
RCsGarage
I bought a small set from Summit years ago but I can't find them. There were only like 5 or 6 in the set. They worked great and held up fine. After doing some reading I decided to go with the Craftsman. More are in this set and the reviews are mostly positive.
6PTsocket
The Summit set is Lang/Kastar, too. There are all kinds of combos available.
6PTsocket
In a pinch, people have had success taking a hardened bolt ( Grade 8 or metric class 10.9) and cutting a slot or two with a Dremel or other cut off wheel for a DIY thread chaser.
decableguy2000
I know the OP bought a set, but for what it is worth the Jawco set has not failed me in any way.
Wamsutta
Amarillo, Texas
I wonder how much different those thread chasing taps actually are from a bolt with slots cut in the sides; they look very similar.
oldldh
Fairhope, AL
Here's three of the sets...
Some a lot more than others...
Snap_cap
The city of the broken bell.
The Craftsman 40pc. set has Snap-On date codes engraved on the thread files. Those date codes are copyrighted, so I would presume that Sears & Snap-On are both sourcing these tools from the same supplier.
Buying the Craftsman 40pc. set ($60+ tax) plus the 8 other taps & dies direct from Snap-On ($40+ tax) still saves you over $40 versus buying the Snap-On RTD set at $142+ tax.
tr0n
Frozen Kanuckistan
i do this regularly. helps to have large shop bolt bins to pick through. the down side is that your nice "sharp" slots tend to wear quickly.
but it's also the only real choice when chasing 3/4" and 1" holes cause who own one that big?
Skin
Boston
Pretty close i'd say. Anything remotely hard or too cruddy and they (Lang) wear out like butter. Ended up getting some nice German made 1/4" drive HSS taps from McMaster for common threads. Never even knew they existed and now they're one of my favorite things in corrosion country. People can squawk if they want about using a tap as a thread chaser but it works just fine. Im trying to make some threads function again so a crusty fastener can go back in and hold on some equally rusted component, not build a space station.
disston
Silver Spring, Md
This is what I do. Sometimes it helps to run the bolts into the threads several times even if not cut as described. Wipe the dirt off the threads of the bolt and insert a few more times. Not as good as making the cuts but helps. If no tools for cutting a notch just grind or file one edge of the bolt.
Wamsutta
Amarillo, Texas
Have you tried the Lang dies on Loctite? I'm pretty sure a regular die would cut right through it. What brand are those German taps?
HomeTheaterMan
+2. They are all the same set. I have the "Craftsman" branded one, but they are all the same. It's a great tool to have.
Dan in Pasadena
Pasadena, CA
I just found this thread AFTER receiving this kit from Amazon:
https://www.amazon.com/gp/product/B00DTEFSWY/?tag=atomicindus08-20
I havent used it yet but seems as though Lang is the company behind most kits per the posts. Bought to use in re-assembling my '55 Chevy truck. I havent used them yet but I feel good knowing most of you guys seem to think they're alright.
PS: The packaging is just a vacuum formed lightweight tray. But that'll be fine for sitting in my tool box drawer most of the time.
