After much research I decided to go with the Sherwin Williams Sheild Crete epoxy for my ~25 y/o garage floor. I did the water bead test and there are spots where it seems to bead, and also puddle due to low spots. So I used the SW degreaser today, scrubbed, and washed. I then used their etching solution, scrubbed and washed alot. I notice later a thin white film, almost like a dust. i can rub it with my sneaker or finger. I assume it is from the concrete that i washed many times. I did this in halves as i had so much stuff and it is a 2 1/2 car garage. I don't expect to paint for a week until the temp/humidity goes down and I'll d that in halves too (and let cure for a week or so). I am also hoping that the 4 kits (each say cover ~200-250 sf) will cover my 668 but maybe not due to the etching so suspect I should get another kit.
As far as this white film... do i just mop it up or try washing again?
BTW - my neighbor (whose home was the same builder) did his too using Rustoleum but he used muratic acid and has the same dust/film.
Both of us notice that the water doesn't actually drain through the concrete but I wonder about this "test" they have you perform to test if it had been sealed. When i etched it did cause a little foaming which the HW solution bottle says is good and means the concrete has not been sealed.
Thoughts?
Thx
Thoughts?
Thx
