White oak finish - make it look old/beat up
duc916
I am restoring a old cart that is made from white oak. I need to add some new boards and want to age them. I have looked around the internet and see articles about fuming, dye, staining, etc. I am not a woodworker so I want to keep it simple. Any good way to distress or make some white oak boards look old?
TONE
Have my wife vacuum around it. That should ding it up perfectly.
astroracer
Mid_Michigan
The easiest way to do this is to pick up some gel stain that is close to the existing woods color. Pick up a COUPLE of colors. Do a few test samples on drops and mix and match the colors until you get somethng that matches. If there are any other colors in the mix they can be matched in the same way.
I just did this on an antique bed I rebuilt. Took a bit of T&E but it came out nice.
ry%3D400
Trying out colors and mixes.
ry%3D400
ry%3D400
All done. It looks even better now because it's been a little over a year since I completed it and using some furniture wax and polish has blended all of the colors together.
ry%3D400
Mark
smedly
Savage, Mn
Not sure exactly what you are looking for, but this was a new pine panel.
Beat with chain, wire brush and awl
Stood on board when it was on gravel, then some rebar
Painted it black
Sanded and scraped the paint
Burned it, which was easy to get carried away
Stain and poly.
I wasn't reall going for a "weathered" look which uses some other techniques, I wanted it to look used.
With the poly
RivennHewn
PNW
Ammonia fuming is a traditional way of finishing oak.
Build a tent over the piece, and place open containers of ammonia in the tent.
How much, and how long you leave it varies the finish.
Lots of info on the interwebs
D
duc916
Thanks for the help. I like the fuming and vinegar/steel wool look
PugetDude
Superstition Mountains, AZ
Stay away from the burning. It doesn't make new wood look old, aged or antique, it just looks like someone took a torch to it. You can do a better job with some judicious distressing, then a careful dye/stain application.
Finish it , set it up, then hire Tone's wife to vacuum around it for the lived-in look.
Good luck, post pictures of the finished project.
404
Mass
And put the ammonia dishes on camp stoves under the tent.
This goes back to 1900 at least. Sometimes an entire room would be done with hot ammonia vapor to darken the look. They sent a little kid in to light the burners..
justanengineer
Motor City
Some of you fellas have funny ideas about what age and distress look like in wood. :headscrat
JMO, but I'd leave the lumber in the back of mine or a buddy's pickemup for a week or three along with a rusty chain or two and a few blocks of hardwood. Let things bang around a bit and get sun bleached, rotating frequently then stain.
