White Rust Bullet Floor with B516 Flake & Clear
Garage Flooring
Grand Junction, CO
Customer just sent us some great pics of a white Rust Bullet Floor with flake. Admittedly, this system is a bit overkill for most of us. 6 coats total. 2 gray, 2 white and 2 clear.
Before
After
03roadking
That looks awsome! Almost kicking myself for just going with grey and flakes! The white looks really good
Theo911
that does look really nice but I'd be terrified of tire stains and other discolorations on the white. Are the newer products exceptionally resistant to stains?
bselfsc
If you use the white and flakes... it would be two coats base, one coat color, flakes then two coats top coat..??? calculating (estimate)...Thanks Billy
G
Garage Flooring
Grand Junction, CO
He did 2, 2 and 2.... Based on our experience and customer comments, with white, unless you are perfect, you will need two coats. You could likely get by with one coat of clear on a light flake
Theo911
Justin can you explain in the article what it means that it passed industrial coating requirements? Im assuming that means that its practically indestructible. Thanks
