Who has a 32mm socket and some calipers handy?
CZ Eddie
Austin, TX
Please measure the inside diameter of your 32mm socket.
I'm guessing it'll be 32.2mm but need verification if possible.
Have got a 32.5mm nut and need to order a socket for it.
Could take it to the store but that would be a PITA right now.
drtyler
Same here. Generic Taiwan 32mm socket.
GJ socket hoarders, this is the time for your 1-9/32" socket to shine. Does it even exist?
33mm would likely work, but that's another odd size.
Bighead38
Rockland County NY
I’m actually sitting in the garage and could measure some but not sure if I have inside calibers that work to get an accurate reading for you.
Jersey Drew
Is it a high torque fastener?
my craftsman (90s era USA) 32mm is closer to 33 (probably 32.8ish) and 1-1/4 is about 32.5 ish both 1/2 inch drive 12 point
neophyte
Pennsylvannia
1-9/32” = 32.54mm.
Apparently 1-9/32 is a size that was made and used for plumbing applications.
neophyte
Pennsylvannia
3/4 Whitworth or 7/8 BSF
Is 1.3 Inches across the flats, which equals 33.02mm
33mm sockets seem to be a thing, as are 3/4Whitworth dockets(although likely harder yo find in the USA than in British Commonwealth countries.
I’m not sure that .5mm would cause much of a fit issue in a docket that size.
Rabid Badger
1-9/32 socket by Proto, $15.42 plus shipping:
Lucid Moments
Gainesville, Ga
32 mm deep impact by Tecton measure out 1.258 inches or 31.9532mm according to my caliper. Measurement errors probably induced by operator.
lardy1
Sorry. I double checked both my 1-1/4 sockets and neither are as big as I posted. 32.14 was the largest. That was before coffee this morning.
gigamel
Mine are 32.1 - 32.4mm.
ISO/DIN standard:
32.08 - 32.48mm
Not going to fit a 32.5mm nut
A small 33mm is a better bet, ISO/DIN for 33mm:
33.08 - 33.48mm
Mgdoug3
KY
I know you won't want to use a 1-1/4" socket. I needed a cheap wrench to modify to work on hydraulic couplers. It was 32mm but I took a 1-1/4" wrench, made it thinner and then had to open it up a little.
