Who has the "Heaviest" work bench?
Delirious
Mine is not as pretty or as clean as some of the benches I have seen on here... But it is pretty hefty, weighing in at just under 8000 lbs before the vise, anvile, clamps, and trinkets.
I think its pretty cute albeit a little dirty.
Sorry about the mess, since I have found this forum I have been driven to clean things up.
ADSR
There is a member here with a 1 foot thick 5 x 10 table top on here. There pics are here somewhere. It's crazy!
Yours is very nice as well!
Nick Danger
Albuquerque
What gets me is that it has lugs, in case the bench is moving around too much and needs to be bolted to the floor.
D
Delirious
The lugs really were to keep the legs from jumping or sliding, tho the legs were not allways attached to a piece of deck plate.
They were attached to a 200 ton flywheel punch aboard a naval vessel. The table is a piece of the deck plate from the ship.
Jarhead0408
Who knows?
I can't believe no one has asked about the vise yet!?
Care share the details? Jaw width, make and model?
Awesome bench btw.
D
Delirious
Awesome bench btw.
Thanks, my grandfather found it somewhere when he was younger. Its a rather large Columbian vise, I really never looked for any info on it, before now I never had a reason to talk about it haha.
Looking around on here, it seems like you guys "get it" so I will do my best to clean things up a bit and research my own posessions haha.
I will make a shop post in the pics section.
plow
Louisiana
Delirious;452070 [IMG said:
http://i79.photobucket.com/albums/j133/Del_ereious/Mobile%20Uploads/20150104_130009_zpsa93f5638.jpg[/IMG]
Really Dude! A PLASTIC dust pan??
ADSR
Looks like it's collecting dust up there. I guess it's doing it's job :lol:
plow
Louisiana
An another thing! get those fire extinguishers serviced.....You know the ones. Tha
e Ansul under the fan and the Amerex by the welder. :;
Steevo
43.49600, -112.04300
That bench ( posted by the OP) is awesome!
Any event that would require it to be bolted down would be a "kiss-your-***-goodbye" event anyway.
I wonder what that base was originally supporting? Must have been a fairly large machine.
Oh, and that anvil in front of it is a mighty excellent one, too.
Steve from Socal
Hutchinson Ks.
How big is the table, I have an angle plate from a large boring mill. It is solid cast iron 36X36X132" weighs right around 8~8500 pounds.
Steve
LXCam
/me looks sadly at his wittle 3Klb table and wonders off with head hung low and in shame. :sad:
Damn dude, you got a nice collection of bigass chit between the table, vise and anvil, nice going!. Obviously you do a serious amount of welding, but what's your trade?.
D
Delirious
Steve
Its ~4'x8' the top is 1 1/4" thick the legs are solid cast, there is only about 6" of space under the table, there are two 1'x3'x4' cast balast pieces occupying that space.
The machine it was attached to was a 200 ton flywheel press aboard a ship.
D
Delirious
Thanks, I do weld but my shop is truly a hobby shop, everything works tho and is used regularly with the exception on the tig machine due to the lack of a foot pedal.
I dont have a trade per say, I was a finish carpenter for a bit untill I got into managment. Hard to have a real trade at 24.
D
Delirious
That floor plate weighs in at ~15k!! Holy moly! Sure It would NEVER EVER move but you would have to engineer the floors and build the building around it haha. But, if someone is willing to spend 5k on a chunk like, that plus shipping, im sure they wouldnt mind.
It would be kina cool if I could get my hands on an 8 or 9' vertical boring machine's bed. It would make a great poker table for the man cave. :pimpflash
Steve from Socal
Hutchinson Ks.
Nah,
You just have to have a different mindset, the first picture I posted was of that table in my two car garage along with a lathe, mill, drillpress and big vertical bandsaw. I parked two car in there as well. The floor plate is heavy and big but, it really need no special floor itself, if I moved with my forklift the floor would have to be able to carry the weight of the plate and the axle holding it up about 30K pounds. That sounds like a lot until you break it down, 30K across 4- 10 inch wide tires is 750 PSI roughly. Well within the limits of most floors. Put the plate on six legs and each leg is bearing 2500 pounds, a 5 inch square base is 25 square inches, do the math.
The forklift would be the bigger one in the picture. The little one move the blue table around.
Steve
Nick Danger
Albuquerque
See post #5.
Diesel Dan
TN
To clarify the punch press did not weight 200 tons, that was its max punch capacity.
Our 2000 ton presses weighted in the 1.2-1.3 million pound range not 4.0 million pounds.
Nah,
We have a bigger/older/rougher hyster with a 50K lb lift capacity. Granted we move heavier stuff but our floors are in the 12-15" thick range. If you need a work bench that large you are going to be putting heavy stuff on it. I'd want at least a 6" thick floor under it. That's just me.
