danmcph
One month ago I thought grease, is grease, is grease. Uhhhh, wrong. Then I read that I should use Moly for shafts and Non-Moly for bearings. It seemed like Lucas X-tra heavy duty and Schaefer 221 were recommended highly so I bought a tub of Lucas and a Tube of 221. Then in my continued online googling I learned that the Lucas is Polyurea and shouldn't be mixed with other greases. Damn, I thought grease was simple.
So here is what I service: Kubota tractor, a **** load of 4WD that are used in extreme environments. (I am from Moab Utah and own a Mercedes Unimog, HMMWV, Steyr Puch Pinzgauer, Early Blazer etc) along with dirt bikes, trials bikes, 4-wheelers etc. I also have trailers and a lot of shop equipment that needs greasing. On top of that I have a number of firearms that require grease, i.e. full auto belt fed WWII stuff. In other words, I have a ton of zerks and other items to maintain.
So, at this point I am at a loss as to what to stock and when to use what and when. I know that once I start greasing with one formulation either lithium or polyurea I need to stick with that grease for that item. The Schaefer 221 says it is an all purpose grease and can be used on bearings as well as splined shafts (think PTO for my tractor) so I am thinking I will use that grease for everything and then use the Lucas for those items that are grease once and forget it like wheel bearings for dirt bikes etc.
Am I barking up the wrong tree and what am I missing?
