Merkava_4
I think they're powerful and ****.
Snap-on OEXL series wrenches are my favorite.
I agree...... only wish that I had a full set of them. Anyone want to part with some?????
I like extra long double box ends personally. To much chance of slipping with an extra long open end.
Yah I have SAE and MM I'll let you have em for $16.00 shipped![]()
Sometimes a long open end is the only tool that'll do the job. Try changing the right upper control arm on a Lincoln Mark VIII without one.
Great....... send me the list of what you have and what you want.
Changing the upper control arm on any car can be a daunting task if you don't have the proper tools. I need to do the upper control arm bushings on my 1969 Cadillac Commercial Chassis, and I have been procrastinating for over a year now. It is one of those jobs that you don't know how long it is going to take, nor do you have any idea as to the problems that you will encounter. To make matters worse, the upper control arm ball joint has an eccentric on it to make front end alignment adjustments.
The upper control arm is a piece-a-cake because you don't even need to take the spring out; the spring goes between the lower control arm and the frame rail. All you have to do is unhook the shaft bolts from the frame and then unhook the upper ball joint from the spindle; control arm is out.![]()
Thats what a crowsfoot and a serpentine belt tool are for.
One problem that I have encountered is that when you try to take the nut off the stud, the stud will start to spin.
This is going to go OT briefly...You mean the nut off the upper ball joint? I never had that problem. Isn't the ball joint riveted to the control arm in 3 places? I just drill out the rivets and replace them with the bolts that come with the new ball joint.
If I was going to take the upper control arm out, I'd want to go ahead and replace the lower ball joint since it's the one that's having to endure the load all the time.
I used a regular length Gearwrench when I changed mine. The rear upper control arm nut was a little hard to get to but I can't seeing it being much easier because the wrench is longer. They sure did put that accumulator in the perfect spot to keep you from putting a box end on it though.
I'm glad you brought this up. The UCA in my Mustang is bolted in, just as I would expect from a replacement. However, the bottom is riveted in and they don't sell bolt-in kits for it. You have to buy a whole new LCA just to replace the ball joints. The local Mustang parts supplier said that was because the load was too great on the LCA so they can't be bolted in. I want to just drill out the rivets and use good, hard strong hardware to bolt in a new one. You guys think its safe?
Aren't old cars a treat to work on???
