Who makes good garden hose?
lardy1
I see some threads regarding couplers but nothing pertaining to the actual hose. I bought a couple MIUSA 50 footers last year and am quite disappointed. I'd like to stay with domestic but I've learned to swallow the import pill when necessary.
I need something relatively light for the little woman to drag across the yard and I'm not looking for the latest marketing gimmick or new gizmo. Just a well made garden hose.
TIA
dogdog
flexzilla makes garden hose, but I have never used it. Seems good.
I usually just buy the "commercial" quality ones from the three ware houses... Sam/BJ/Costco. Last one was almost 10 years (I think) had to repair it once, out side past 10 years unhook and drain water in the winter. This one is heavy though.
Oh right "Contractor" grade is what they used in their marketing terms.
Terra Nova
Had the never-kink brand for a while, they were okay and fairly resistant to kinking, but they broke down eventually. Been very close to pulling the trigger on a Flexzilla hose but keep reading reviews about mold & mildew problems with them. Seeing some hanging on houses around here I see where the reviews aren't far off.
Went with the Sears Craftsman all rubber hoses. They kink fairly easily but are durable, flexible, and affordable (lifetime warranty but without a Sears around that doesn't really matter). Don't know if they are available anymore, maybe Lowe's or Ace carries them?
Bubba Fett
Eastern NC
It's hard to find good hose these days.
I have an old green-with-a-white-line hose in the front yard for years, and it has been great. Problem is I don't know who made it.
I haven't really been satisfied with any new ones that I've tried. The "never kink" ones seem to kink constantly. I do know one thing; stay away from hoses with aluminum connectors. They will result in galvanic corrosion, and you may end up having to replace the spigot. Use anti-seize at least, but it's best to go with brass.
WWheeler
Middleofnowhere USA
We use two 100' hoses. One for front and one for back. Three years in a row from blue and orange 'big box' stores I've bought at least one of the most expensive 100' "lifetime guarantee" "professional/contractor grade" "never kink" that they have and every year I need to buy at least one new one because of horrendous kinks. I need to buy two this year. I have less than zero good advice for this thread. I'm just in to see the replies.
EDIT: Before that I had two black rubber 'Craftsman' hoses from, Sears that lasted several years, but they don't exist any more and I've not yet found anything equivalent sold locally.
jonshonda
Wisconsin
I have flexzilla and like them. Only think I don't like is the asphalt sealer on my driveway rubs off on the hose, which is kinda odd and more of a cosmetic complaint.
danho
SW Oregon
Another vote on the Flexzilla. I have both the standard and the Pro versions and like the Pro better which is a fitting upgrade that is easier to grab and is more durable. The sun fades the hose after a couple years, but the flow is good, very little kinking and it rolls easily in cold weather.
mrb1
Miami County, Ohio
200.png Have used two of these for more than 5 years in the garden, power washing vehicles and the house. Lightweight, work great. Nice ends. Easy to pull in and loop around a holder. Readily available at Lowe's, and "assembled" in the USA.
laser3kw
northen IL
I got the Bionic Flex pro a few years ago and have been real happy. They are not stiff and are maneuverable with out restricting movement or steering. Added benefit is they rewind on the reel or loop onto hanger real easy.
mike93lx
Richmond, VA
View attachment 1658395 Have used two of these for more than 5 years in the garden, power washing vehicles and the house. Lightweight, work great. Nice ends. Easy to pull in and loop around a holder. Readily available at Lowe's, and "assembled" in the USA.
I bought one of these to try out and it seems decent so far. It's nice to be able to pack it up quickly and compact, but I haven't compared flow to a regular hose
pwschuh
Mid-Atlantic
If you're not familiar with the Project Farm channel on YouTube, he does a review/test of a number of different brands of hoses and picks his favorites.
SARG
Northeast
Just bought a Flexilla in the new "earthtones" .
It's my second from the maker and they are a little pricey ....... but so far I like it.
Xcursion88
We have 100' of Flexzilla hose that's now on year #3 or 4.
Zero problems...
Definitely a quality product
Ilikeike
Northern Ca.
The Continental hose has worked well for me.
I have these on 3 sides of my home
This one is around 18 yrs old
Merica !
our local Ace hardware had them last year. But it’s a Heavy beast
Sumboodie
AK
That's what I use. More or less a small firehose. I threw out the old hoses as these things are easily 10x better. I can carry 500ft of hose without even sweating. Try and do that with a regular hose!
Takes up less room too.
About the only thing it dosn't work well for is low pressure applications, like the discharge for a small water pump, and certainly not the suction side.
honcho
Near Sodom & Gommorah (aka Wash. DC)
In the 80s while living in Germany, I bought a Gardena lightweight hose on an aluminum hose reel. It traveled the world with our family and was really a great hose until my son mowed it into several pieces. It was light and flexible and somewhat resistant to kinks. Unfortunately, I was never able to find the equivalent in the States. We now have the black rubber Craftsman/Goodyear/Continental hoses which are durable but much heavier.
engineer2
Chicago burbs
I have a couple of Flexzilla hoses. Probably 5 years old by now.
Pro:
Stays soft even in cold weather. Not sure, but it looks to be some kind of silicone rubber.
Very kink resistant.
Lifetime warranty. The outer cover split on mine. Sent them a picture, they shipped me a new hose even though I no longer had the receipt. Save your receipt as added insurance.
Con:
The lime green turns black from mold/dirt. Doesn't hurt anything than appearance.
The aluminum fittings require a tool to unscrew them at the end of the season. Not a big deal. Of course for die-hard GJers a Snap-On wrench is the only suitable tool.
Now if I could only find a decent extendible watering wand. The kind with multiple spray settings.
71firebird400
I have two Gilmour Farm & Ranch 90' hoses that are five years old. Nothing fancy but they're made in the USA and carry a lifetime warranty. I had one hose develop a leak after a harsh winter; Gilmour shipped me a new one and all they asked for was a photo of the damaged hose.
BombShelter
State of Hockey
I use hoses everyday for work, the old Craftsmen Rubber Hoses with the flat side were hands down the best in value and quality. I might have 300'-400' of them and have only lost one over 15 years, it might have been run over by a forklift but I can't remember. In the winter I use them for my ice rink and never had one split.
About five years ago we needed some hose for a job and someone bought a few hundred feet of the Pocket Hose, those are life transforming. They definately aren't commercial grade but they are super light and they compress most of the water out of them when done. It's a treat to put all of that length in a five-gallon bucket and throw it in the truck instead of reeling in the regular hose and lifting it and the trolley up on the bed. These need to be babied, you can't leave them in the sun and cars can't drive over it. I recommend using 25' lengths in case you do break one. They do constrict, which is frustrating when using something like a sprinkler, but you can kink it to stop the water. Buy the largest diameter, the small diameter has a very low flow rate.
In a pinch, most home stores have a contractor grade hose, always buy rubber and look at the end connectors for quality, most hoses with plastic covers or metal springs at the ends are ****. You should be able to pinch the hose and it should feel soft and rubbery, don't waste your time or money with the cheaper vinyl hoses.
Xcursion88
Sounds like a beast of a mower. What kind? 😎
bonneyman
Desert SW
On the recommendation of a friend many years ago I snagged a Craftsman premium garden hose. It has a hexagonal profile instead of a round one, making it tougher and more kink resistant than a regular hose. Plus HD brass fittings on the ends. It had a lifetime guarantee, don't know if it's still available. But you might be able to find some NOS stockpile somewhere.
akasrick
south jersey
I bought one at Sears and a second one at Lowes after Sears closed. I don't bring them in for the winter. I like them.
akasrick
bonneyman
Desert SW
I used it mainly for work. Dragged it around parking lots and over concrete parapets, hot roofs, leaving it laying in the sun. No problems. Since then I've used repaired beater hoses for work as theft while you're on the roof became a concern.
GypsyR
upstate SC, USA
I got sick of fooling with traditional style hoses in my camper and the RV folks suggested a Zero-G hose. Folds up like a firehose rather coiling so it stows away a LOT easier. Or you can wind it up if you want. I got used to using it and now don't want a traditional plastic/rubber style hose for the house either.
sick467
Hughesville, Mo
The heavy all rubber Continentals are the best bang for my buck. They are not cheap, they are not "kink resistant, they are not light....but, they last a long time and take a lot of abuse.
SlotlessMan
NW WI
Flexzilla's decent quality. They do get a moldy unappealing look after a couple of years though.
The natural color that someone above mentions would be the way I'd go, wish they had that when I bought mine.
ATC
VA
I have 125' of the Craftsman hose in front of the house. I think it's about 6-ish years old. It lives outside, laying wherever it was used last. 95* heat or 10* in the winter. It gets drug from one side of the house to the other over gravel driveways, around rock walls, concrete walkways, etc...We even drive over it in the gravel driveway sometimes.
Looks and works like new. I wish I bought 10 of them before Sears went under.
Before the Craftsman hose, I had a black rubber hose with 2 yellow lines down it. Huge brass connectors...spring on the spigot side. That thing was 15+ years old used just the same as I described above.
humpty
Minneapolis, MN
I have the Flexzilla and its been a good hose, it doesn't kink any more than any other hose. My hangs outside all summer, I haven't had any issues with mold or mildew.
I also have a no kink hose that we bought at my lost job, it was not cheap. My guys hated and threatened to throw it away. I can see why, it doesn't kink but it does have some memory and it the ribbed exterior is only good for the fence's pleasure, not anyone trying to pull it along. I'd be disappointed if I had bought it, but it was free and I use it as the second hose in a 2 hose set up so it stays on the holder most of the time.
