Who makes Klein quality flexible snake drill bits?
rogersmithiii
I have to run wires through a wall that has firebreak cross studs. I think I need to use a flexible drill bit to drill the holes.
Who makes Klein quality flexible drill bits that are 72 inches long?
Thanks
The Cobbler
Greenlee are what I have. they are not HSS so they can dull easily if you hit a nail . a bit tricky to use the first time . I would try to feel my way to the centre of the block by swinging the drill back & forth between the cavity so you get the hole as centered as you can and not be against the drywall ( nailing issue)
One vendor makes a lever tool for helping to center bit once it’s in the hole. I don’t know what brand I have, but think it’s only 5’.
That’s much more complicated than what I saw way back when, 25+ years ago. Looked more like loops of larger gauge wire.
