chrisbowles
- Joined
- Dec 3, 2014
- Messages
- 35
I'm needing a air hammer. I have looked at the aircat for 115.00 IR has one for 50.00. Both had quick change end, does the aircat hit harder?
shadow dog please enlighten me on how to "turn up" the 3050. just got mine after borrowing one from a tech next to me. it is ***'s.
• Variable speed soft touch trigger provides featherability for greater control
• 4 position built in air regulator varies power for different applications
The IR 118 Max is a bad mofo as well.
Josh
Josh
Does the snapon air hammer have a lifetime warrenty? Or when it dies I have to pay to get it fixed?
Strongest ?
CP717
Requires .498-Inch diameter chisel shank tool in order to handle the extra power.
1,800 blows per minute; 2.69" stroke; 3.13 cfm average air consumption
Are air hammers rated to see which is strongest similar to torque for impacts
Yep, our shop bought one just for removing stuck wheel bearing hubs. Most times it knocks em right out.
I really could have used this today. Soaked wheel bearings in penetrating oil all last night, didn't budge this morning. Had to hit them with a sledgehammer for an hour
maybe use a bigger hammer next time...
if wailing away for an hour with a sledgehammer is what it took to knock it loose, it's doubtful an air hammer would have helped much....
CP 717 or the identical (made in the same factory) Astro Pneumatic. You need .498 chisels but it you really want to pound on something this gets it done.[/QUOA. I know they look identical but are you 100% sure there made in same factory?
Another vote for the Snap On 3050. Any one know why the website shows it's not available?
Where did you get the quick chuck on your RRH12P-TS ?
Isn't the CP 717 made in Japan and the Astro in Taiwan? Where did you get your info that they are made in the same factory?
