Who makes the longest 1/2” ratchet
Big Bad Jon
Was able to find this on Matco , Snap On and Mac only have ≈26” ones.
Looking for alt alternatives, the longer the better.
Matco one is here.
jblnut
In the Middle of MN
I’d rather not have to buy a 3/4” 1-1/2” socket
Are you wanting a longer bar to put more force on the socket or for reaching farther or what’s the driver for the long length ?
If you put a looooooooong 1/2” drive ratchet/bar/whatever on an 1-1/2” socket and give it the beans you may certainly destroy the ratchet/bar/whatever. My basic rule of thumb is once you get to 2.5-3x the drive size you need to step up to the next larger drive size. I’d step up to a 3/4” drive and a pipe before finding a longer ratchet in 1/2” drive.
ecotec
If it was me and I was dead set on 1/2" drive, I'd use a piece of pipe as a cheater. However, if it was me and using an 1-1/2" socket, I'd prefer 3/4" drive. I also have a 42" 3/4" drive ratchet.
The Wright railroad ratchet?
T444e
I could never justify one, but it is a such a cool ratchet/war club.
I can admit justification had nothing to do with the purchase, I just wanted it and Zoro had it at a price plus a discount code I couldn't say no to. It has come in handy over the years. I decided to move into 3/4" drive sockets after putting an 8 foot cheater on a 1/2" breaker bar and jumping on it. I was very surprised the anvil didn't break.
ecotec
I have a 40ish inch 3/4” breaker bar and a 3/4” impact. My 3/4” ratchet is pretty terrible. It isn’t long enough, for sure.
I can’t remember the last time I used my 3/4” impact (like 20 years ago). It still has a deep 19mm in it.
The breaker bar I have used, in lieu of using a cheater bar.
T444e
I don't have a 3/4" impact, but will get one at some point. Some the places I have used the ratchet an impact wouldn't fit.
ecotec
Unless you work on heavy equipment, the 3/4” impact is not needed as much anymore. Weighted sockets will take out crank bolts that a 1/2”impact and regular impact socket would not.
T444e
My issue is are not with crank bolts. While I don't work on heavy equipment, I have impact sockets upto 2-3/4" which have been used and I have found 1/2" impacts are not always enough. But I have the long ratchet and I always get something to give one way or another.
Wrench97
Southeastern Pa
You are correct I haven't touched my 1" in 3 years and the 3/4" I think I used twice both time on lug nuts I never should have needed it on.
NUTTSGT
Northern Central Ohio
Is this something to be used on a regular basis ? Does it actually need to ratchet or do you need a breaker bar ?
For the rare occasion, I might use the breaker bar to break it loose and a pipe over my longest 1/2" drive ratchet.
Big Bad Jon
What is the torque spec of the 1 1/2" nut?
These are nuts that hold an industrial washer to the floor via concrete wedge anchors. Because of the floor anchors, I do not want to use an impact.
The floor anchors have to be checked for “tightness” weekly, but no torque spec is listed. And because they have to be really tight, I want as much leverage as possible.
I’m trying to stay away from 3/4” drive because I don’t have any other 3/4” sockets. I know if I go 3/4” I’ll need to own the entire set
Wrench97
Southeastern Pa
I ask because usually what happens when you get too high a torque on a 1/2" is the square drive end breaks.
There is always the option of using a 3/4 to 1/2 adapter on a 3/4 ratchet.
Wrench97
Southeastern Pa
Quick look shows 250-300 ft lb for 1" anchors so doable with 1/2" for sure.
NUTTSGT
If you are worried about buying a 3/4" set, I would suggest a simple and basic set from your local tractor/ farm supply. You can get "cheap" set for way less than $100.
If you buy a set and break a socket, just buy a readily available replacement.
Off hand internet search.
JobSmart 3/4 in. Drive SAE Mechanic's Tool Set, 20 pc. at Tractor Supply Co https://share.google/qbohLmyg8rFhoI5NW
Wrench97
Southeastern Pa
It’s not insane torque, but ≈24” ratchets aren’t doing it. Ideally I’d loosen the nut slightly and snug it back down.
My 3/4" snap on has 42" handle, with the head probably 45" overall.
Most 1/2" I've seen max out at 24-26".
I use to work with a guy that has Quinn 3/4 extendable that extends to 39".
Big Bad Jon
I don’t know, extendible ratchets just seem “cheap”
I bought the Matco 36” for $250 on eBay. We’ll see how it works. I have a feeling I’ll be buying a 3/4 set before too long. We’ll see how far down that rabbit hole I go.
mike93lx
Richmond, VA
Just use a breaker bar. You don't need a ratchet for this at all
rust in the eye
Chicagoland
Doesn't sound like anything particularly precise here. Why not a cheater?
If just snugging up existing fasteners why use a ratchet? How many degrees are you turning this thing? Seems a breaker bar do as well.
