who makes this belt sander?
Stang65
Ontario NY
Hey guys, this is on Craigslist and he is asking $200. I'd have to convert it from 3phase to 110v or 220. Any idea on the make? Is it worth messing with?
Thanks.
Jeff.
exmaxima1
Midwest
Thanks.
Jeff.
I checked the CL ad in Rochester, and everything about it looks like a Rockwell/Delta/Milwaukee.
Make sure you check the drive drum bearings, as they are a ***** to replace and you risk cracking the casting. Also look for gouges in the guards----I wouldn't $200 for a machine that needs parts or is all full of gouges. Good Luck.
zkling
Agree with exmaxima. Looks like it has had a full life already. Can you see if under power or does the current owner not have 3ph either?
dkroth
Rochester, New York
I saw that one when it went up a week ago.
Sorry, I don't know who makes it but some of the bits and pieces look like Delta/Rockwell.
That said, you're basically buying a belt sander without a motor and no accompanying disc that needs most of a restoration for $200. To me that's a steep price. Keep shopping. There are better deals out there.
Stang65
Ontario NY
Ok thanks guys. I have a motor sitting around that would be perfect for it. I was thinking of offering $100 but I'll keep looking.
Hawk
Kannapolis, NC
If I could get it for 25. I might consider it with the things needed to get it running.
Keep Shopping.
454ragtop
Carver, MA
Tough crowd here. It is Rockwell Delta, table shown is worth more than $25.00. If the seller can demo it, probably worth $75-$100, especially since you already have a single phase motor to use on it.
Jim
dkroth
Rochester, New York
Thanks, Would this one be better or worse?
http://rochester.craigslist.org/tls/5215428437.html
-Jeff
Jeff,
I was going to send you a link to that one yesterday but held off due to the lack of a real table for the belt portion of the unit. I think that one is generally intended to be used in the horizontal position where the work piece is held on top of the belt. I understand that application, but I find MANY more uses for the belt coming at it in a vertical orientation with a decent table to work from.
BTW, the seller - Don - is a ******** tool collector. He's at most tool related auctions in the area and he bids to win. He may actually have a real business buying and selling.
Cruzan80
Denver, CO
The table on the Craftsman is designed to be able to be mounted either at the end of the roller for horizontal work, or against the vertical lift of the sander, or against the disc as shown. All depends on how it is installed at the time. That being said, I wouldn't be surprised if the stand was part of the reason for the current cost. I have seen a few as low as $50, especially when I was living in Pittsburgh.
nine4gmc
Dallas
The belt guard is worth about $75 alone, it's worth $200 in parts but if you could get it for $100, it would probably be worth it.
Edit, the upper roller is usually the problem, if it's not damaged, that piece is worth $200 alone.
