texasfiremedic
I have looked through Snappy web and can't find. Unless I missed it.
Is it a proprietary bit? It is not a Torx. I have called a 5 point star but can't seem to find a match.
This goes on a VP 44. I have to get a new pump and will have to add a stealth plate over the electrical package to tap a wire on the pump internally. If tapped outside the pump warranty will be voided. The problem is I am still debating about putting the tap on.
Anyway any suggestion would be helpful.
Is it a proprietary bit? It is not a Torx. I have called a 5 point star but can't seem to find a match. This goes on a VP 44. I have to get a new pump and will have to add a stealth plate over the electrical package to tap a wire on the pump internally. If tapped outside the pump warranty will be voided. The problem is I am still debating about putting the tap on.
