Who uses removable caulk? What for?
roc_on_the_rocks
South central Indiana
loganb
Omaha, NE
I have only used it to do things like seal reusable form work corners or other things that I want easy to remove but need short term liquid tight joints
mike93lx
Richmond, VA
To facilitate removal in case of future service.
I don't have experience with removable caulks, I assumed they seal well until they're peeled off. Wrong?
Silicone is removable. When you need to pull your toilet or shower body in a decade, the last thing you want to find is that the removable caulking you used didn't seal as well as absolutely possible.
You aren't talking about anything that needs regular service so there is no benefit to a product that is more easily removed
PCustoms
VT
Seams that these removable caulks are only meant to seal drafty old window frames until it warms up next year.
Why would you expect any other uses, obvious or not?
Feels like on of those "hack" videos where it just exposed that the contractor or homeowner is just a hack, using the wrong material in the wrong way
545_days
Texas
Clever use of a product in a way that wasn't foreseen by the inventor is ingenuity. Some alternative uses will be ill advised, but some potential use cases such as sealing reusable forms as listed by a poster above are definitely not hack work.
Edit to add: I wouldn't use it for sealing around faucets, toilets or showers, but am interested to hear of other unconventional uses for the product.
