guy48065
The pump on my power washer was leaking & not making pressure so I installed new seals, pistons & a new regulator. No more leaks & makes pressure but it doesn't feel like as much as before so I installed a gauge. On a Youtube video the pressure drops to a few hundred psi when the trigger is off, and climbs to max right after you pull the trigger. "Unloader valve". Mine is not doing this. It stays at 3200psi and when I pull the trigger it drops to 1500 or so and maintains that. Adjusting the regulator will drop the 3200 "stand-by" pressure but when the trigger is pulled I still get the 1500psi output.
Did I buy a dud regulator or is there something else wrong with this pump?
Engine RPM is solid and the pump is an Annovi Reverberi XMV 4G32.
