Whole Home Surge Protector Install
rockcrawler
Dallas, TX
I’m about to begin the install on my surge protector. I‘ve read that it is important for it to be in the first breaker location in the panel. Is it as simple as moving all of the breakers up to make room for the surge protector breaker? I’m using a flush mount kit for a cleaner install.
Yes, I know there is an Eaton breaker in my GE panel for my shop. I’ll be swapping that out with a GE breaker along with running the proper wire from the house to the shop. The shop builder’s electrician did this. I have all the wire, I just need the time.
LXCam
It’s not necessarily the first breaker location as it is next to the feeder terminations. So in your case the bottom of the panel.
Also it ever so slightly helps to install the largest conductors that fit the terminations and keep them as short as possible.
BrandonV
Arizona
Do these have an advantage over the ones at the meter from the PoCo?
If you have a utility which is giving you a meter socket TVSS for free you're good. Most utilities that offer this do it as a subscription service.
Arguably its the best as it will clamp before the panel.
SlappyWhite
Upper Canada
mike93lx
Richmond, VA
Looks like the oven breaker is fed from the top? If so, I'd move that one to the top of the panel and put the surge there. I can't imagine I'd move everything just to get the surge all the way at the bottom
PCustoms
VT
Surge is supposed to be in the first positions after the main.
Leapfrogging a few breakers or moving them all up one slot won't be bad.
mike93lx
Richmond, VA
I know. But in the panel is better than no surge
That sub looks to be fed from the top. That one should probably move. The second one up. Doesn't appear to have much slack.
PCustoms
VT
Second?
I'd move this one up one slot and replace it with the surge suppressor.
Then move the shop breaker somewhere else. If swapping that wire out, and the buss allows it, could go in an empty slot up high. Otherwise I'd shift the 3rd double pole on the right to the top.
I think this is a main panel since the NM-b on the 100a breaker on the right side is feeding his house... it only has a 3-wire feed but i also dont see a bonding screw....
R
rockcrawler
Dallas, TX
This is the main panel that is located in the garage. The bottom right breaker feeds the sub panel located upstairs and the breaker above that feeds the panel in my shop.
R
rockcrawler
Dallas, TX
I think he was stating that the upstairs sub panel is fed into the main panel from the top. Which it is. This would give it plenty of slack to move it up.
rixtrix1
Chandler, AZ (from west NE)
When we upgraded our main panel to 200A to feed my new shop, they used a Siemens panel and surge protector at my request. Same company, different division also replaced our heat pump a week later and wanted to charge me $1000 for a surge protector for that. Would it be necessary to have a separate one for that or is it a lack of communication/sales hype? BTW, the heat pump is roof mounted, so if it gets hit by lightning, it's probably toast anyway. Will the main panel surge protector protect the 100A shop subpanel, too?
PCustoms
VT
Most heat pumps require on ate the unit.
$1k additional is insane.
R
rockcrawler
Dallas, TX
From what I understand, and I could be wrong, the surge protector is supposed to protect everything in the main panel. This in turn should protect the sub panel in the shop and the sub panel upstairs in the house. I hope.
mike93lx
Richmond, VA
I put an additional surge unit in my pool subpanel. It wasn't worth hoping
