joe.striper
Just put a deposit on this Ames Lathe tonight. 36" bed 8" clearance. 1" headstock also got 29 collets, 1/8th to 1". My first oathe. I'm pretty excited!
I have 3 lathes, my favorite by far is this monster VDF. I found it for sale ($600) locally when looking for a 14x40. I ruined my trailers 7000 lb suspension, but it was worth it. I added the DRO, a taper attachment, and VFD 1 phase input 5 HP. It has metric and imperial threads up to 14 inch pitch - yup 14 inch pitch! Also has all pipe pitches. I think it is just post WWII, primo German engineering and manufacturing.
I have had an Atlas 12x36 since I was 17, I'm on my third one now! I also have a 12 x 48 Rockwell wood lathe from a school that shut down the shop.
I have made hundreds of parts, and even more repairs! Screwed up threads, to actual parts from scratch to save a machine. I also used it to twist iron square bar for railings I built!
I said I would never move it once I unloaded it from my trailer, but now I have a new shop out in the back. I need a crane to load it on the upgraded trailer (now 14K gooseneck). Hope my car lift will pick it up off the trailer!
That's a neat machine Joe, but not the most practical without lead screw and longitudinal feed. What do you primarily plan on using it for?
Larry, I did indeed get two cases of collets for the chuck. I've never used a cillet system before, so I look forward to the opportunity.In the very bottom of the picture is what looks to be a Jacobs Collet chuck, Did you get the collets for it? If not hurry back and see if they are still around.
http://www.stevensmachine.com/used/2015/05/25/jacobs-model-50-collet-chuck-10-collets/
The above is not your model but it shows the collets.
lg
no neat sig line
Thanks. It is indeed a Buck chuck.Nice score. That 6-jaw chuck alone is worth the $300.00.[emoji106] It's hard to tell from the markings but it appears to be a Buck chuck, or possible a Pratt Burnerd.
Lathe looks to be in great shape.
Mike.
I fell into a good deal on this 9" Logan Model 1400 last spring. It's a small utility lathe ,wish it had quick change gear box , but it does what I need. So far after buying some basic tooling I'm into it for around $400
Man I am jealous you guys. I have saved $1000 from side jobs for a lathe, I have the space, but these rarely come up on CL around here and the two I have looked at have been junk with high prices. I am almost ready to pull the trigger on a Grizzly G4000 but I would much prefer an older lathe.
I do have a question though, I am retired and live in my "forever" home so I would never have to move it but how do you guys move those large lathes when you move? Do you have to hire someone special to move them or do the movers do it for you?
Wants around $1000 .... worth it?
I have an opportunity to get a 12X36 Enco 110-2075. Been in storage for awhile, covered but unheated, so there is some rust on the ways and some corrosion. Not a lot, but noticeable. Cross slide has no slop, but the feed screw has a lot of build up. Runs on 220, 3 wire, but looks like it should be a 4-wire. Not shown, but there is a brand new 4-jaws still in the crate. Lot of the tools shown look unused.
