littleboss
- Joined
- Feb 2, 2018
- Messages
- 134
I live in north Texas. I put a Pioneer 24k in my shop. I previously had a wood stove, 50k btu hanging shop heater (propane) and a 2 1/4 ton window unit. (propane heater is still there). I typically leave the shop at 60 during the winter and heat it up before going out there. During the summer it's on 82-85 if I am not out there.
What I have found is that
1. In the winter I don't like the "cold" air that the mini blows. I am used to hot air from the propane heater or the woodstove. The mini blows warm air when you first turn it on but then as it reduces capacity the air is cold. I don't like that at all.
2. If I leave the thermostat low until I am ready to work then it takes hours to get it up to temperature. Now the propane heater IS twice as big so that makes some difference of course. Also the propane heater blows air all the way across the shop. The mini on high blows about 2/3 as far. the Mr Heater only blows hot air no cold air!
3. In the summer the mini doesn't cool as fast as the old window unit did either so I have to turn it on hours in advance.
So for me I use the mini in the winter to keep the shop at 60 as it's far cheaper than propane. When I start to head to the shop I turn the Mr Heater on to warm it up quickly and then run it. When I leave I cut it off and the mini takes over again.
In the summer I either have to leave the thermostat on 78 or wait a long time for it to cool down.
In my opinion I wouldn't have bought it just for heat but it's over twice as efficient as my window unit was so it's good for cooling.
