sberry
Another reason why I like Z-Wave over WiFi devices
All of my IOT (VOIP, etc) are on there only dedicated subnet and I am using pfSense as a router
Like this,, ha
In the dust collection system, the soft start valve prevents the gates from slamming when the system is pressurized. This is the true purpose of the soft start valves. I liked them so much I added to my main header and my milling machine. I build systems to be as hands off as possible. The dust collection system only has two user controls - a main power switch that powers up the system and energizes the soft start valve and a remote control to turn the cyclone off once it's running. Zero user interaction to line up dust collection to a tool or start the cyclone. Turning on a tool takes care of all of that. Same with the CNC router, it controls dust on it's own.
On the mill, when the control is powered up, the soft start is energized, making air available to the draw bar and accessory air blow nozzle.
My other "stupid trick" that gets a good "wow" is that I can gin up the whole home theater... lights dim, screen drops down from the ceiling, window shades close, AV turns on, etc. I was going to add a "Pre-roll" video with "welcome to our theater" but wife thought it was too cheezy.
BS, that’s pimp. You should totally do it. I just figured out how to control my Onkyo receiver today so I should be able to do the same type of setup less the screen dropping...mines permanently attached to the wall.
What projector do you have? Mine pre-dates automation (and the wheel I think).
I have a JVC (I think) 4K United but just control via s Harmony hub using the HomeSeer plugin. Basically let’s me automate anything the Harmony can talk to. Theoretically the projector has an API of some sort, but good old IR seemed easier than reverse engineering it since I don’t think there’s a HomeSeer plugin.
I have had reasonable luck with Nodered and MQTT for things that don’t have a native HomeSeer plugin, but it gets a bit time consuming.
Hadn’t even considered using IR....brilliant.
I’m going to try that. Awesome.
I even use this integration to unroll my movie screen once a week if it hasn't been used to it doesn't wrinkle. Homeseer tracks whether the "Watch Movie" button has been pressed, and if it hasn't all week does an unroll at 3AM once each week.
The Harmony hub thing is pretty cool. Remote is very usable for the family, and you can also use it to integrate devices with Homeseer, and kick off events based on things that happen on Harmony.
For example when someone hits the "Watch Movie" button on Harmony, homeseer captures this and dims the lights. I can then detect when my Plex server starts or pauses a movie, and use that to dim/off the lights.
Now if only I could get automation to clean the popcorn maker...
