Why are my Hout drill indexes backward?
AmericanMechanic
I have a couple sets of USA bits from Kodiak Cutter. I believe they are in Hout indexes.
It would make sense that when you open the index the largest bits are in the back, and so forth, with the smallest to the front. However if you position the index that way, the size stampings are on the back
So basically I have to use the index with the largest bits hiding the next smaller bits and so on. I suppose I could try to fill the trays around inside the index, if I never wanted to close it again (due to length of bits) which I may do.
But why did they design it backward???
Wamsutta
Amarillo, Texas
Perhaps you're looking for an index like this.
Provincial
Near Salem, OR
The assumption is that you will keep the index closed when not in use. If you open the index, you see the size markings until you flip the top tray up, then you see the markings on the next tray, and so on. You are expected to select the drill bit before you flip the tray up fully.
The expectation is that if you want the drill bits to spend their storage time standing up, you will buy a drill stand, rather than a drill index box.
A
AmericanMechanic
Thanks for the info on a drill bit stand. Looks like most are only labelled so you see the markings from above (not in front).
Yes, that red drill index looks to be proper. Surprised the Hout isn't built like that. Google search reveals even Irwin and others label theirs like the red one.
Maybe I'll just try to flip mine around in the index I have and just not close it.
Thanks for the info / help.
dr_clyde
Holland, MI
Huot indexes are designed to be closed when not in use. I have never had a problem with mine.
I much prefer the Huot index to any of the other cheap ones.
6PTsocket
If you buy indexes, buy Huot. I got a set of spur bits for half price because the index was exactly like that red one and was all beat up and deformed. It was easily straightened because it is made of the thinnest grade of Chineseium. That index make aluminum foil look sturdy.
A
AmericanMechanic
SOLUTION!!
To anyone reading this in the same dilemma, after looking closely at the drill index, it was actually remarkably easy to flip each of the three trays around. In fact, if I was to grind 3 of the bits just a bit shorter, I think it'd close up if needed. Over time the bits will get shorter with sharpening, so it'll be fine.
