Why are my nuts blue?
bluedog225
Texas
I ordered fancy bolts, washers, and nuts.
The nuts are coated in blue wax. I’ve seen this before, but didn’t think much of it.
Why? Won’t that mess up my torque values?
mike93lx
Richmond, VA
First guess is to make them easily identified for inspection and then also as a lubricant/protectant? Although being galv, wax isn't likely protecting much
bluedog225
Texas
I thought lubrication and torque values were mutually exclusive. That is, I vaguely recall reading that mating surfaces should be clean and dry.
cgrutt
I thought, lubrication and torque values were mutually exclusive. That is, I vaguely recall reading that mating surfaces should be clean and dry.
Believe its because the galvanization process adds a thick and sometimes rough coating to threads that can interfere with obtaining proper torque specification and/or cause galling.
Dan in Pasadena
Pasadena, CA
Depends on whether they were electro-plated or hot dip galvanized. I'd ASSUME automotive parts would only be electroplate. Hot dip is used on things like sign and light poles, etc. Maybe(?) that process would be used for heavy machinery?
cgrutt
Says on receipt they are hot dipped.
cgrutt
Ok, a bit surprising but my experience is that hot dip is a thicker coating. Granted my experience is in decades of heavy civil construction, not automotive parts.
I'm just referring to fasteners that OP posted no idea what he's using them for.
MoonRise
IIRC, the OP is building a building with a 'deck' and stairs hanging off of a masonry structure.
As to the blue nuts, send flowers to the wife/SO and see if that helps. 🤣
Torque values for the desired preload and/or bolt tension can vary a LOT with 'dry' fasteners. Like 25% or more. Clean and consistently lubricated fasteners can bring that torque-vs-preload scatter down around 10%, but is more work to do all that.
Waxed hot dipped fasteners can help with more consistent torque-vs-preload values and help minimize galling of the rough zinc on rough zinc also.
And the spec for that grade nuts says that they WILL be lubricated with a visible (often blue) wax lubricant coating. See above paragraph for why.
brit vet
Manchester, England
Bluedog225 was lying in a hospital bed following a minor operation when a young gorgeous nurse approached his bed and asked how he was doing? “Are my testicles black” he asked struggling to speak while having gas and air. I have no idea said the nurse. Bluedog225 asked again “are my testicles black I need to know?” The nervous nurse said ok I’ll take a look and gently pealed back the bedsheet exposing bluedog225 equipment. She gently moved his willy to check his testicles then placed it back in place. No Mr. bluedog225 your testicles are not black she said. Bluedog225 pulled the Oxygen mask to one side and said “that was very nice nurse thank you for that but what I said was ARE MY TEST RESULTS BACK?”
Codyboy
S.E. TEXAS
Torque values? Do you plan to actually torque that type of hardware with a torque wrench?
I've built several of these racks over the years that hold the equivalent weight of three VW bugs in the air for years.
Not a single torque wrench ever touched the hardware. About 5 or 6 ratatats or more seem to work great!
