why are rafter vents so expensive?
vavet
Ashland, VA
I'm about to embark on the insulation of my detached garage. I want to install baffles between the rafters (trusses). I can't believe how expensive they are. They run $1.60 to $1.90 each! That doesn't seem crazy, but when you figure they're just a floppy piece of plastic and I need 32 of them, that's a little chunk. I figured it something they'd sell enough of to really benefit from economies of scale.
K13
St. Albert, AB Canada
How much cheaper do you think something like that is going to be given it has to be manufactured, packaged, shipped and sold with some profit? It's not like washer where a thousand of them fit in a 4" square box.
kbs2244
It is not the cost of the item in a retail store.
It is the cost of shelf space and inventory carrying vs price.
This is a classic case of a penny per item cost vs a dollar per item price.
tthornto
This seems like a very practical way of making your own baffles. Especially if you have a issues like a steel roof you can't staple to, or post frame constuction with rafters 8' or more on center. I don't see why it wouldn't work with stick framing and 16" or 24" on center rafters, you could possibly even eliminate the string because you would be stapling in more places.
CombatNinja
For what it's worth, making your own baffles as shown in the links is way more effective than the store bought junk. Most of them are only 10-12" wide and people put them in 24" OC construction. Then when the fiberglass is installed over them, they get crushed because they are so flimsy. Using store bought foam baffles probably gets you maybe 35-40% of the ventilation you could have with site-built. They are seriously that bad.
rnixon
Cardboard baffles sell for 65 to 85 cents each... / 16"/24"centers
