Mac used to sell a set
Maybe its the 2am, but why aren't ratcheting wrenches made in 6 pt? I mean they are ratcheting so indexing of the wrench the normal 6 pt issue should not be a problem.
I prefer 6 point sockets and 12 point wrenches. Plus with ratcheting wrenches I bet the ratcheting mechanism would break before you notice any benefits of 6pt vs 12pt.
Americraft is the Brand name-Made in the USA-very well made and sturdy-maybe not what you had in mind? These ratchets have BALLS! Different mechanism than the GW models......Cranky![]()
Ratcheting spanners are ideal for where you've got limited room to turn and limited space to get a socket in there. Under these conditions it's usually going to be a lot easier to get a 12 pointer onto the nut (or bolt) than a 6 point.
shampoop and HandyManny, just food for thought...
When you start working on modern day engines, you will need 12pt sockets. Even most of the domestics are switching to 12pt fasteners. Or if you did your own engine build and bought good hardware like ARP fasteners, you better have 12pt sockets or you're up **** creek.![]()
yea, but how often do you completely disassemble a modern engine?
If you draw a circle and place 72 equally spaced teeth around the outside of it, then draw a 6 point hex inside and finally draw a 12 point hex inside you can see which one eats up more space. A 12 point takes less space so can be made smaller to fit in tighter areas.
This is compounded when using 12 point fasteners as opposed to 6 point. 12 point would be stronger as well because the load is distributed more evenly. The strength properties of steel are such that you don't need the thick banks of steel you get with 6 point, it's wasted material. A 6 pt wrench will break at the thin corner where the force peaks on only 6 areas.
This is completely incorrect.
Take a regular hexagon (that's a hexagon with equal length sides to the uninitiated) and draw a circle around it with the arc of the circle the same distance from the points of the hexagon at each. Now, make six dots along the sides of the hexagon, the same distance from the circle as the points are. Now, connect only those dots to each other with lines. You will see that there is NO difference in size, and with the existing six weak points on the tool, adding six more points doesn't dramatically add to the weakness of the tool.
Still, if you take a 6 pt fastener and cut the corners off till it becomes a 12 pt the head becomes smaller but the strength stays the same. This way tools can be made smaller for the thread size of the fastener required. That's the concept I had in mind.
