Why do carbon brushes need replacing and what are they?
Nealcrenshaw
Cleveland,OH
I notice that a rotary hammer i'm looking at mentioned that it comes with a extra set of carbon brushes,i'm assuming that it has something to do with the motor,but not sure,and how do you replace them?
krusty the clown
Member Emeritus
niangua, mo
the bruses are what connects the electical power to the armature. there are a soft material so the commutator doesn't wear, so they do. they need to be replaced after a while.
gotmud13613
Upstate, NY (Brasher Falls)
Must be a HF tool, All of mine have also came with extra brushes. I check mine maybe once a year but I haven't had any that needed replacement yet (some are getting close though) there grinders seem to use them up more than any other tool.
Here is a pick of the rotary hammer I think you have and I put an arrow where the brushes go (should be one on each side)
russlaferrera
Central Virginia
When you turn the machine on you will see sparks . This is where the brushes meet the armature. On both sides of the motor you should see round plastic disks with screwdriver slots, under these are the brushes.
bchee
Texas
Who else besides HF provides replacement brushes?
I had a HF grinder with extra brushes and thought it was a neat feature, but then I thought maybe it's a sign of lower quality...
I don't have a lot of power tools but I can't recall other manufacturers that provide brushes
