Why do large drum fans only come in 2 or 3 speeds?
Bondo
Greenfield, Maine
Ayuh,.... How much air ya tryin' to move,..??
I have a few squirrel cage fans, taken from hot air furnaces,...
Donno the Cfm's of 'em, but they move alota air,...
Originally used to blow heat through whole houses,....
Wire in the right switch, 'n ya might be able to run infinite speeds,....
Radix2
the thumb!, MI
The reason is that these types of fans use PSC motors - the speed is determined by tapping into the windings at various spots. It is difficult and costly to create much more than two or three taps, plus the required switch and wiring. Many of these large fans use standardized motors and that is how they come.
ewang
Central WI
You could probably retrofit a ECM motor on it and that would give you infinite variability....
But would also be expensive!
LS6 Tommy
Northern NJ
About the only way you get quieter wihout giving up CFM is to go for a HUGE diameter blade with a steep pitch angle runing at a low RPM...
Tommy
Blue98GT
Tommy
And that is exactly what I'm after. I have a 30" Direct Drive drum/barrel fan and want to slow it down. Some for the noise factor but it would be nice to have a lower flow rate when higher flow isn't necessarily needed.
LS6 Tommy
Northern NJ
If you had a belt drive fan you could increase the driven pulley diameter or decrease the drive pulley diameter (or both) to reduce blade RPM.
Tommy
csp
Franktown, CO
The intended use of these fans is to move lots of air, so why would they incorporate a low speed? There are other types of fans for low volume.
Not saying your idea isn't valid, it just doesn't follow what these fans are made for.
Farmall450
Marengo, Illinois
Exactly. Got my dad the 36" or 38" Maxxair for his birthday and its two speeds is more than sufficient. Wouldn't buy that big of fan to do what a box fan can :dunno:
