Why do old drill presses only have three mounting holes (dumb question maybe)?
ching0n
I understand that 3 points is how you get a coplanar surface but it makes for a wobbly mess on a drill press. I would love to just put stem casters on a floor standing drill press but that's a no-go for 3 mounting holes. Am I missing something? How were old drill presses mounted/rolled?
tool_scrounge
Southern California
Usually bolted to the ground if needed. No sane manufacturer is going to recommend caster wheels unless the base is specifically designed to be wide/long enough to be stable. You might consider using a adapting a commonly available mobile base for a bandsaw.
Last time I made one of these, I used steel tubing instead of wood. In your case you might consider adding a thick plywood deck.
L
speed bump
Butte Montana
Drill presses aren't intended to be rolled. They are generally designed to be permanently attached to the floor as they are top heavy unless you get a really heavy duty machine.
C
ching0n
well, forget casters for a minute, how 'bout just leveling pads? Maybe the 3 points was precisely to avoid people putting casters on them?
FrankLee
seMI, 48317
In your Craftsman example, there are actually nine coplanar points on the base; six around the perimeter of the polygon and three around the column bore. Three of those points have mounting holes. Using the three mounting holes on an uneven floor will still secure the press to the floor without rocking, but obviously not all points will contact the floor.
IMO, it's much safer to move a floor-standing drill press on wheels than trying to muscle it around without wheels or moving it with a hand truck.
Quality of the casters, quality of the floor and cleanliness of the floor are important factors. Stabilizers are needed to prevent rolling.
I move my drill press on a mobile base when needed. I only move it parallel to the longer distance between casters, ie, front to back direction.
I use only one bolt to secure the dp base to the platform.
C
ching0n
Looks like you've put some thought into it. Is there any reason you'd only use one bolt if as you say, bolting all 3 gives you steadiness?
I have drill presses dating back to the mid 1800. If there are any mounting holes, there are 3. Exceptions: One has none and another has 2.
I think the new chicom ones are 4 bolt. You ever wonder why 3/looked into it?
FrankLee
seMI, 48317
I use one bolt because all nine coplanar points are contacting the plywood base.
Using three bolts on an uneven floor would prevent rocking, but only three(?) points could be touching the floor, and not necessarily the three with the bolts. In fact, if the bolts were tightened too much, it could crack the base.
Beerhippie
Far NE Oregon
What's wrong with how it's shown in your picture?
1725213418868-png.2175583
Looks like the answer right there.
speed bump
Butte Montana
yes but if you're elevating a drill press on 3 points say 1/4", it'll tip to one side once you load it asymmetrically.
Give it a shot. It's a lot harder than you think it is. There's a reason a tripod is a lot more common than a quadrapod.
Also why are you elevating all three points?
C
ching0n
a tripod or an anvil has a center mass down the center. The elevation would happen due to the offset of putting any type of feet in those holes. Here's a picture of Frank Lee trying it (not recommended per his words):
FrankLee
seMI, 48317
Correction…
Those were WTF photos I saved from a for-sale ad. I never tried that, never would, and still think it's a terrible idea..
