Why do wrench sets have missing sizes?!
ecotec
Well, the 28 piece Cman pro = 6-21mm minus the 20mm wrench = $145 on sale...assume half that cost is for the 14 metric wrenches (which is conservative as the SAE sizes go up to 1 1/16") = $72. I imagine that for $90 you can find a comparable quality (Amstrong full polished maybe?) 20,22,23,24 mm wrenches. Also, I think the S&K's are pretty fugly, and there is that whole thread on the quality...
You do get a matching set w/ the S&K's though...
You could buy the full polish 18pc 7-24mm from Wright for $232 on Amazon... and they are beautiful.
derosa
Oceanside, NY
How the hell would a 1954 USA made car have metric anything? I'm having a hard time believing it's not 3/4"
It had to do with a shortage of the muffler bearings at that time requiring them to be imported from Japan who was only producing them in metric.
johninct
I believe spark plug threads on my 1947 Farmall H are metric. Also, there were no metric bolts used on old things but because of wear, rust, bad manufacturing tolerances , etc. sometimes a metric wrench will just fit tighter.
BDT/NWMN
Erskine, Mn
Is that guy is still waiting for his Studebaker?
Think of deleted sizes in a wrench set as options.. You could buy the options; as desired. --hopefully.
Wonder if that Studebaker had optional power steering and automatic transmission?
PBCampbell
WV
:dunno: :headscrat :wtf: :willy_nil
I think someone maybe is yanking some chains with this post. On another note I'm still trying to figure out where I lost a 23mm combination wrench. I'm sure I had one, but can't recall ever running into that fastner size.
Keel
LaLaLand
I don't know.. they tend to set different size sets, the 7 pieces isn't going to have all the sizes, then they have the 15 piece and 27 .. etc..
I do wish socket sets 1/4 drive would stop with the useless 5.5mm
WWheeler
Middleofnowhere USA
I've used my 5.5 mm sockets a lot. Just off the top of my head it gets used a lot for hose clamps, coil packs, & body & trim.
Tim C
X2. 5.5mm gets used a ton in car dashboard screws as well as the plastic covers you have to remove to change the oil on most cars nowadays.
Sent from my XT1254 using Tapatalk
chris142
apple valley,ca
Dodge truck lugnuts are 23mm.
derosa
Oceanside, NY
that and 23mm are 2 sizes i've never used but have, have used 4.5mm hex on old italian bicycle parts.
californiaHank
I guess I'm weird ...
I bought a 5.5 mm socket to add to a set that was missing it.
The 5.5 fits M3 hex nuts and hex bolts - common on small electronics stuff.
If you've got both SAE and metric sockets in your tool box, 7/32" is amost exactly 5.5 mm, so you don't really need it.
You usually see 5.5 sockets in European metric sets, but some American sets skip them because they assume you've already got a 7/32".
wvrailroader
West Virginia
My Ford F-350 company truck uses needs a 5.5mm socket to take the trim off around the headlight to change the headlight bulb. Glad my Gearwrench set included that size.
Gmonkee
Sometimes with a tool brand you need to widen the field of vision..
Pretul sets I have skip 16-17mm but carry the 5/8" and 11/16" so if I have both sets no skip. They were arranged before 18mm was a factor so a skip and no SAE to step in but no big deal. I added an old 18-21mm from loose stocks and then 20-22mm to kick the set up to 7/8" . And it packs small.
Those with severe OCD need not apply but I get work done with good quality cheap India made wrenches daily. Subbing between standards and all the tricks that work.
At home are better wrenches with full range to 22mm but the cost of loss (a real factor for me) is much greater.
They do the same jobs equally well, nothing to complain about.
Aqua-Andy
I have a set of Mac wrenches that came with a 23mm, in over twenty years it has never been used. If anyone would like to purchase it to fill in a set please let me know, as it is too small to be used as a doorstop and I don't need anymore paperweights.
Dtech494
Kitchener, Ontario
The 5/8 is equivalent of 16mm.
The 20mm is used on 90's gm gas filter.
Also on 200's oil cooler lines.
The 23mm that is talked about fits some tie rod end nuts.
I used the 23 mm today on a 2006 Dodge charger tie rod lock nut.
It has 23mm on the replacement tie rod it was originally 24mm.
There is a 26mm suppose to be used on some euro applications or large lines.
I think they skip uncommon sizes to reduce the cost of the set.
As you've likely noticed that when you buy that one wrench it costs quite a bit compared to the set cost too. Unfortunately for us.
MikeF2316
Thornhill, ON
I used my 23 mm wrench on a nut on the driveshaft of a '67 Peugeot 404. And my 5.5 mm socket to change the heater motor in a relatively new Buick. And for the longest time, the only place I used my 16mm wrench was on the nut on the fender on Volvo power antennas. But in the last few years bolts that used to have 17 mm hex now have 16.
WWheeler
Middleofnowhere USA
You could always turn that unused wrench into something useful.
<iframe width="560" height="315" src="https://www.youtube.com/embed/dOHHMtYr2KE" frameborder="0" allowfullscreen></iframe>
That was with an 11mm. Just think what you could do with a 23mm.
jerseykat1
Central New Jersey
Why is it that so many wrench sets are intentionally missing some size(s)? :headscrat Craftsman does this - they don't sell a 20mm fully polished wrench, but they carry 21mm-24mm! Even Snap-On omits 16mm, 20mm and others in certain sets. This annoys me :mad: I need 16mm and 20mm! Anyone else agree with me?
population control. They want to make your blood pressure rise when you find out that you don't have an 11mm and that's the only size you need for the job that's got you stranded on the side of the road.
If any tool company leaves out a 10mm they should just go out of business immediately.
jerseykat1
Central New Jersey
haaa he is the reason tool companies leave out the 11mm he uses them to go fishing..
wafrederick
Holton,Mi
This includes 18mm and 15mm too left out.1 3/16" sometimes in the SAE sets and Craftsman does not sell this wrench size
Theruse
Maryland
Ironically today I found out I needed two 16mm wrenches to remove fuel filter connectors. Even more difficult is that they should be flare nut wrenches or crows foot. So yes 16mm are used and when i look at my tools I have a 20mm wrench which is not part of any set and I can see I have used it many times!
ecotec
I actually have a 20mm stubby for some reason--only stubby wrench I own and I definitely bought it for a project. Probably something on my '98 GM truck.
If it is a brand new SK 20mm stubby, it was from an SK giveaway a few years ago. I have never used mine. A lot of people on GJ got in on that giveaway... and have an SK 20mm stubby that they are unlikely to ever use.
WWheeler
Middleofnowhere USA
lol, the thread that never dies. I somehow stumbled upon it and apparently not noticing how old it was revived it after it laid dormant for 9 years, and that was 5 years ago. Now 5 years later it's brought back to life once again. :LOL:
FWIW Gearwrench makes a pretty nice 44pc SAE/Metric long pattern 12 pt and 28 pc std length SAE/Metric 6 pt sets of wrenches with no skipped sizes IIRC. I bought both 6 or so years ago for my work box, partly because the price was really good for comprehensive sets that size but mostly was just trying to avoid having anything nicer around the crew of sticky-fingered rogues I'm stuck bringing my tools around every day (anything co-worker owned from a pro brand like Snap-on, Mac, Matco, Cornwell, etc in the building tend to grow legs), and they've held up perfectly so far. I somehow haven't even managed to lose one yet.
bubinga
16 and 18 are often skipped. Makes me mad too, as they are needed, I didn't think 20mm was often used, what are you needing a 20mm for?
msharley
Central Pennsylvania
Even the 10mm?
