Why do you need taps AND DIES
A_Pmech
IL
I know! I hate solid dies. Geometric threaders are fine though.
I prefer to single-point whenever possible. Luckily, I rarely have to make external threads less than 3/4" dia.
safetyman665
Aloha State
I tend to use a thread file to clean up any buggered threads on bolts and studs; it's just easier for me. I use bottom taps to clean internal threads. I rarely have a need to cut new threads.
Toolhorder
Montana
I use both once or twice a week since my thread chasers are slim in the metric dept. Do I remove some metal? Probably but it works better than nothing in a pinch.
Toolhorder
Montana
Until you can't fit the file where you need to restore the threads...:(
jethro29
central delaware
they are the kind of thing that when you need them "YOU FRIGGIN NEED THEN" they are priceless and I will always have a SET at they ready.
A_Pmech
IL
Bolts I buy have the unthreaded portion oversize for the given die size. Do you turn them down in the lathe?? Seems like a lot of work to me.
Modern bolts are made boy cold upsetting the threads. The bolt shank is substantially undersized for making cut threads to standard engagement.
ajchien
Los Angeles, stuck on the 60 freeway.
Only time I really use dies is for adding more thread to a bolt that isn't fully threaded, like when needing push bolts for a rotor or pulley.
^Same here.
I also use them when I dont have a chaser of the right size. Yesterday I needed a 8-32, so i Used a die instead. The smallest sae chaser I have is 1/4-20.
Depends on what I'm doing. If it needs to be as new as possible, I go out and buy new hardware. Otherwise, modifying hardware/cleaning it up is faster than making a trip to the store.
