Why electric tape on handles?
skipskip
Upstate NY
Why do people put plastic electric tape on tool handles?
I see it most on pliers, but I have seen it other tools too.
What's the point?
It makes such a mess when you try to deal with the tool.
Skip
nissan_crawler
Wichita, KS
What's the point?
Skip
Heck if I know. Some genius's version of an "insulated" tool?:shocking:
toolnut
Lockport,NY
Most likely they could be working on electrical systems a lot. The cheap way to avoid sparking your wrench,pliers ,or ratchet under the hood. I usually use the plastic dip to insulate handles against a "accidental" spark or weld. Using electrical tape as a grip would not work well as oil or grease would make it slippery.
Diablo
I do it on my channel locks and Kleins for two reasons, one to identify them as mine on site as everyone usually has the same kind. and two to prevent the top of the factory insulation from tearing and fraying. Ive wrapped my screwdriver shanks in tape to prevent shorting cct's out.
nissan_crawler
Wichita, KS
I just pull the negative lead on the battery if i'm worried about arcing something.
If I'm under the hood, or welding, or doing anything remotely related to electrical, that's pretty much step #1. It helps prevent the stupid things.
If we're talking ac voltage, then it seems it would just be best to buy the proper tools if you have to work on hot wiring.
kwhitelaw
I did it in the past to help identify my tools over someone elses without having to etch.
nate379
Palmer, AK
A bunch of my pliers are because the factory rubber worn threw, split, started slipping, etc.
I suppose I could plastic dip them, but electric tape is like 0.10 a roll and I always seem to have 15-20 rolls laying around.
AmickRacing
Rapid City, SD
Electrical tape is usually the easiest since everyone has a roll hidden somewhere.
Heat shrink tubing is also a pretty slick thing too, especially some of the heavy duty stuff.
wrenchr
Well once the goo from the tape starts getting everywhere you will not have to worry about them slipping out of your hand!!
Diesel_Crawler
Canada, NB
They tape up a bunch of the nobs on one of the lathes at work, Just what you said happened. You always had to go was your hands after you used it :wtf:
fomocoforrester
If your going to do it, to improve the grip, identification, or whatever, you really should use self amalgamating tape to avoid all that mess and unravelling that you get with the ordinary stuff.
bgott
Houston, TX.
I think it started back in the old days when electrical tape was made of cloth. They used to wrap their tools with the cloth tape to keep their hands from slipping. The practice carried over, now a lot of people wrap handles with slippery plastic electrical tape without even really knowing why they are doing it, it was just something Grandpa did.
Diablo
I heatshrinked the already insulated shafts of my Wera screwdrivers. I have them in the field all day and they tend to get beat up the heatshrink just helps prevent that a little bit.
c130herc
I usually use F4 tape to gain some grip on tools that I mainly use on greasy jobs, also use it to enlarge the handle area to shape my hand better.
krazykev
the battery on my renault megane scenic is under the drivers seat. it would be very foolish to try and undo the battery terminal without an insulated tool because it would short circuit on the seat frame. this could set of the seat belt pretensioner and / or air bag. do you get the idea now?
