Why no 24" Long Fixed Head Snap-On 1/2 Ratchets?
DSLTRK
PHELAN, CA
Has anyone wondered why Snap-On doesn't offer a 1/2" Dual 80 24'' fixed head ratchet?
I mean, they make ridiculous ratchets like the super long 1/4" flex head, so why not something more useful.
With the popularity of the Tekton and MAC (and upcoming Proto) versions, can we petition Snap-On to get a die made and start producing their own version?
I've seen their 24" flex head, but for serious torque, the pivot is not up to the task when they are 24" long.
Thanks for the input.
Here is a visual of the tekton version:
drewvdw
Central Illinois
Why do you say the pivot isn't up to the task? I haven't had any problems with mine. The drive broke before the pivot did...
Know Wosad
Because the concept is goofy. That's what breaker bars are for. My go to 1/2" ratt is a flex head that's 10 1/4 long...after the breaker ba(OH. KTC BR4F from Franks tools)
TK-421
Pflugerville, TX
If I had something so tight that I was worried about breaking the flex joint on a 24" ratchet, I'd be reaching for a breaker bar and not a ratchet.
General Geoff
Allentown, Pennsylvania
In the rust belt, it's not uncommon to find bigger bolts with long, super rusted threads that will fight you to the last turn. Having a longer ratchet makes the work a lot easier. Some would argue that's what an impact wrench is for, but they don't always fit where you need them, and a long ratchet doesn't need air or a battery to work.
I might treat myself to this new ratchet as a birthday gift to myself next month. I don't care for the flex joint on a 1/2" ratchet either. :beer:
TK-421
Pflugerville, TX
I'm so glad I moved to the south. The heat *****, but I prefer heat over snow, ice, salt, and rust all rolled into miserable season.
pi_guy
N/A
I have both.
There are places a flex head works great. I have not see any issues with it and my dealer has said lean on it and see if you can break it. I asked that question when I first bought it. "would the flex hold up"
The short 1/2 flex head is another I find very useful as often I am spinning big nuts on gearboxes and bend the handle 90 and use it like a crank. Before I break out torque wrench for final set.
shockwave
Marietta,ga
I believe they have had these forever since I always pass up for the flex as a matter of fact my snap on click torque wrench is about that length too
This is a great flex ratchet I have had for years and the head will. Break before the joint will in most cases
redwrench60
East Tennessee
I've always wanted them to make one of these too. I own breaker bars too but they're not always practical to use in tight quarters or a low swing area, hence the reason I'm not using an impact in the first place. Some bolts with either rust, thread damage or just locktite fight all the way out so a long stout 1/2" drive ratchet without a flex joint is just what I've been hoping SO would make. The 1/2" dual 80 mechanism is pretty stout too.
Fedwrench
Valley of the sun
What's this rust you guys keep talking about? :lol:
Snap on probably waited awhile to offer a super long fixed 1/2 drive ratchet because, their primary customers (flat rate techs) would just use an impact wrench:wtf:
gdocktor3
Connecticut
I feel a flex head 24" ratchet would see more use than a fixed head. Two feet is a loooong ratchet and the capability of offsetting the handle even a little bit to clear obstacles is probably a life saver in many instances. As mentioned, the ratchet head would break before the flex head pin. Living in CT, large fasteners often require ratcheting the entire length of the threads due to all the rust and corrosion. Leaf spring shackle bolts, u bolts, etc. tend to be this way every time from the weather, as well as the stretching and what not.
bobcatdan
Kaukauna,WI
Breaker bars are pointless. I stopped using after breaking them and then using a 1/2" ratchet to break the bolt loose.
MrGiggles
You use a long handle ratchet for reach, not for leverage. Although the leverage is definitely a plus.
When you're reaching down into an area (and generally cannot get a hand in there to hold the ratchet on a fastener) a flex head is a pain in the ***.
The fixed head Snap On is SLL80A I believe.
D
DSLTRK
PHELAN, CA
That's exactly why I was looking for a long ratchet. I already have a long Matco flex. I've had the Snap-on flex heads, and the pivot is not as strong as Matco's, IMO. Head pivot spread the fork one time.
Art From De Leon
De Leon, Texas
Unless you use an extension, or deep sockets, the non-flex length of that ratchet will limit the area where you can use it.
At least with a flex-head, you can use the advantage of being able to angle the handle in relationship to the head to clear obstructions.
L.Cheapo
I have an SHL80A, which is 16 5/8" long for when sh*t gets serious. Its rock solid and I'm a pretty big guy and I'm sure I've nowhere near tested its limits. It is a bit unwieldy, I would imagine a 24" much more so. But sometimes its the only tool that will do. Perfect for changing tires away from electricity or compressed air.
MWEric
Wyoming, MN
I've had to warranty 2 Snap on 24" flexes. Both the same, eventually the teeth wear out on the lock. Also tightening the torx screw repeatedly will wear it out as well. I will be getting the fixed head also, finally.
KEH
Some flex ratchets are basically a breaker bar with a ratchet at the end of it. I have an old Craftsman 3/8 flex and I noticed that a 3/8 breaker bar and the ratchet handle were identical. I don't know which would break first, the ratchet or the handle. I can't speak for other brands.
BTW, are there 3/4 drive flex heads?
KEH
D
DSLTRK
PHELAN, CA
Same here. The torx screw can't take the torque on handles over 17" long.
Sycan
Second from the right, about an inch shorter than the long flex. Real nice ratchet. b81741e634d567df6abc4a58e8b01991.jpg
Sent from my HTC6535LVW using Tapatalk
BajaBound
Nor Cal
I have broke 3 HF 24" breaker bars... I now own a 24" SO breaker bar and ratchet. I have torqued on them but I would stand and jump on the HF bars. I don't think I would buy the fix head, ok yes I would.
redwrench60
East Tennessee
I got my SLL80A in today. Quality is excellent and handle diameter is beefy. It measures .725" opposed to .605" on the regular long handle SL80A. I'm gonna use the **** outta this thing.
