Wamsutta
I watch these guys tear down transmissions on youtube and they're not using any impact sockets. All chrome sockets and chrome extensions. Is there not enough room to use impact sockets on transmissions?
You talking about Hiram Gutierrez?
Yes I am. That guy never uses any impact sockets and I wonder what kind of shape his chrome sockets are in if he uses them on an impact all day. I'm guessing he has some kind of reason for using chrome sockets like maybe clearance issues.
Hiram Gutierrez
It's youtube. I had a customer tell me he watched a video on a particular process and it only took 15 minutes. I explained editing to him.![]()
Although You Tube can be a source of great information, many people are just using what they have available. I know in the factory transmission courses I've taken, I was told never to use cordless or air powered tools to prevent damaging cases and other components but, in the land of time = money, I think everyone uses what they can get away with.![]()
So you're saying you can't pull the motor out of a truck, install it in a boat, ride the boat around and then put it back in the truck and go home in a half hour like the guys on Roadkill?!
A lot of the "experts" on Youtube aren't the sharpest knives in the drawer. I recently watched a video on replacing a rear bearing hub on a vehicle. The hub nut is 36mm. Torqued to approximately 200 ft. lbs. He put a chrome socket on his 1/2 gun to take it off. No explanation why he used it nor any cautions given. Granted a socket that big probably won't shatter but it still should not be done. And if I ever did that I would be wearing face protection and gloves at the very least.
I guess this is a good example of the old adage, "If you want anything done right, you have to do it yourself." Warranty or not.Yea, I had a mechanic that was Ford trained use his impact to set the crush ring/pinion tension on my 8.8 Mustang rear during a new gear set up. I questioned him about this since the Ford service manual has it written out in big bold letters "DO NOT USE AN IMPACT WRENCH TO SET THE PINION CRUSH WASHER. IT WILL CAUSE DAMAGE TO THE PINION BEARING."
About the time he said "Oh, it's OK, I do it all the time", a client of his pulls up in his newer Shelby with a pinion bearing going bad after he changed the gears in it. This was already his second attempt at rebuilding this rear and I wasn't giving him a third.
Mine made noise the next day.
my dad was a GM master mechanic in the 80's, there's not a single impact socket in his tool box, not even 1/2". some of the more commonly used ones are wallowed out. decent sockets just don't explode, not even on a impact
There's a transmission guy on YouTube who reassembles every transmission with the impact wrench. It's nice that he list torque specs on-screen, but he never uses a torque wrench. Ever. Every nut in Bolt he touches gets the rattle gun treatment. Recently, he started editing out the parts where he impacts the nuts and bolts on.I guess this is a good example of the old adage, "If you want anything done right, you have to do it yourself." Warranty or not.
Shortcuts and sloppy behavior like this is exactly why I don't like to take my cars to a strange shop for service -- even the guys who *know* better are too ******* lazy to *do* better. And they know that for the most part, the damage that they do to your car will not be immediately apparent, and they can dodge responsibility for ******* up your car when it fails on down the road.
I hate techs who are so lazy and sloppy in their work that they dismiss the knowledge of the engineers who designed the system they're working on. Just because a tech attended the Ford training course doesn't mean that he's no longer a hack.
I hope you captured video of that conversation so that you can get them to pay for the repairs that you're going to need.
That and possibly because the torques used on aluminum are exceedingly low and there really is no reason to use impact sockets if the most torque you're ever going to see is 20 ft-lb as even Chinesium can easily handle that.Yes I am. That guy never uses any impact sockets and I wonder what kind of shape his chrome sockets are in if he uses them on an impact all day. I'm guessing he has some kind of reason for using chrome sockets like maybe clearance issues.
