There is a lot of confusion in terminology going on in this thread. Wow!
1. Roxul makes a product in the industry know as rock wool it does not, and never has had, asbestos in it.
2. There were many different products produced here in the U.S. prior to about 1978 that were also know as rock wool or similar but were manufactured through a different process and with different raw materials. Depending on which mine these raw materials came from, asbestos was present.
3. Depending on where it was mined, Vermiculite insulation also contained asbestos and it was silver in color somewhat resembling rock wool.
4. Fiberglass is not used in anyway in the manufacture of modern rock wool.
5. Rock wool is expensive.
6. Comparatively speaking fiberglass is far more affordable.
7. Both products, if installed correctly, function as advertised.
8. Vapor barrier is not the be all end all panacea that Canadian builders and code writer believe it is. In colder climates it is great and a wise move. For us folks in more Southern and humid climates, not so much. Our buildings need to breath in order to avoid mold problems.
9. If you find yourself doing any type of remodel on an older home and come across very brittle fiberglass looking pipe insulation, or a black, grey, or silver wall or attic insulation material, STOP! Have it tested before you do anything more...
That said, I recommend Roxul to all my customers...
