TORX drive woodscrews are far superior to any other woodscrews I have used. Much less likely to strip.
Scott
Have you ever drove in square screws with a square bit,the torque is unbelieveable.
Torx has 6 points.
a hex has 6 points.
Square has 4 points with double or triple the possible torque load.
Hence the square drive on ratchets and sockets! Just more stuff to make us buy.
My Volvo has a torx slot on the end of the sway bar that you are supposed to hold while undoing the nut, umm..seriously? Did the engineers not think that the crud inside over 10-15 years would rust that ***** right out?
Look at this, unbelievable.
I didn't even know there was a torx slot in there, got my impact and snapped the stud on the sway bar. I'm still pissed.
To think they engineer a car for it to be worked on later, and even 10-15 years after purchase is quite absurd. The vehicle is designed to be put together on the factory floor as cheap and fast as possible. Serviceability is usually second or third on the list.
I had the same thing on my Toyota's sway-bar. I figured it out, and then replaced the link with an aftermarket adjustable one with regular hex nuts and washers. Problem Solved.![]()
initially I think torx were used to keep people out of stuff, same as the triwing etc.
Torx has 6 points.
a hex has 6 points.
Then there's THIS form of drive which can handle even more torque.
Personally I'm not getting them as its just another set of tools that would be incompatible with every thing else I own without an adapter.
That's what I said about Gearwrench pass-thru spline drive before I got it. Now I don't leave home without it.
Torx has 6 points.
a hex has 6 points.
why do robots prefer torx?
My understanding is that Phillips were designed and used to prevent over-tightening.
