why use ratchet adapter + breaker bar?
sam.coll
Melbourne, Australia
We use them when building and dismantling electricity transmission towers with a 600mm long breaker bar. If you need to crack a really stubborn nut/bolt I remove the ratchet adaptor.
OutsideMachinist
Norfolk, VA
Won't see many times for that I wouldn't think. Though ratcheting adapters/inline ratchets do seem a bit sturdier than ratchets . Generally I use them for torque wrenches.
Dave455
Sussex, England
Generally, a ratchet adaptor is much stronger than a conventional ratchet, so for any application needing more torque than you would want to use with your regular ratchet you might consider a ratchet adaptor!
If you're working away from base, a breaker bar and adaptor minimises the tools you need to carry, and of course, a ratchet adaptor is seriously useful if you have one or more non ratcheting torque wrenches!
Having said that, I seldom use a ratchet adaptor with a breaker bar. I do, however, use one with a Sliding T handle an awful lot! Use both hands to loosen a fastener, then whizz it off with one hand!
The Sliding T and Ratchet Adaptor are two of the most under utilised tools I reckon!
Finky198
North East
The max torque is actually pretty low on the snap on S77 1/2" it's around the 225ft/lbs Well under the rating of most regular ratchets. You can easily break them with a large breaker bar. They come in very handy changing tires road side
H
hautpot
California
Wow completely forgot about t-handles! That appears like a very useful combo.
martin666
New Jersey
The 1/4" and 3/8" I use for tap sockets, the 1/2" & 3/4" I'll use occasionally with a breaker bar for lug nuts, but to be honest I'm pretty **** and have the bigger two because I have the smaller two and would lose sleep if I knew I didn't have all of them!
whyNick?
Midwest
Great question OP, I was thinking of posting exactly the same thing but hadn't gotten around to it yet. I picked up SO 1/2 and 3/8 ratcheting adapters cheap at a garage sale a year ago and they've been rolling around in a drawer ever since. I like the T handle idea and may try that. I may also try a speed handle with one, seems like it could be handy.
Rico.
England
Also... Price up a good quality 25" flex head ratchet and then price up a breaker bar
and a quality ratchet adaptor... big difference if you only need a tool like that once in
a while.
:thumbup:
bobcatdan
Kaukauna,WI
I got a 1/2" one new for super cheap when Snappy ordered one for a guy to warranty. The guy threw the busted one out so Snappy couldn't make the trade. I bought it to go a long with the 36" breaker bar. Can't think of an exact application, but I have found it handy here and there.
rsanter
visalia ca
Breaker bars with the ratcheting adapters is becoming obsolete.
You used to not be able to buy a long ratchet but you could buy a long breaker bar. So the ratcheting adapters was an add on convenience that you added to you long breaker bar
Bob
crewchief888
NW indiana
Bob
Until recently, about the longest (quality) ratchet you could find was 115-18" long. 24" breakers were available. Personally I've never broken a ratcheting adapter, can't say the same for long ratchets
:beer:
