dlwilson
This is really confusing me. I have a Harbor Freight compressor (93271-1VGA). It's 230V, 21 gallons, 3 HP, 3.5 SCFM @ 90 PSI. When I put my 3/8" ratchet on it with a 25' hose the ratchet spins for a couple seconds, and then runs out of air and stops. If I release the trigger for a few second and then try it again, it will run another couple seconds. Repeat.
If I plug the ratchet directly into the quick-release on the compressor, it will spin forever. Maybe a blocked hose? I got another $5 Harbor Freight hose, which did the same thing. As an experiment I shortened the hose to 7' using a barbed fitting. With the 7' hose the ratchet spins forever.
So what's going on? Is there too much resistance on a 25' hose? Or is the hose swelling and shrinking too much? Can I fix this with the $40 Goodyear hose? Seems like a bigger compressor won't fix this.
It happens a lot on brake lines. If you get a brake that stays locked when you leave a stop, more than likely it's the brake hose.
