Why would a 120v device have a two pole thermostat?
Quickstep192
I’m looking to replace the thermostat for a wall mounted towel warmer with a countdown timer.
The outgoing stat and the timer are rated 20a.
Although I verified that the circuit is 120v, I discovered that the stat is two pole. (See attached)
If I install a timer can I connect the neutrals and just switch the hot ?
Q
Quickstep192
Excellent question!
When I disconnect the neutrals and no power to the stat, there’s continuity across the neutrals, so would you agree it’s not switching the neutral?
Clearly the stat needs a neutral to operate, but why would they provide a load side neutral if it’s not being switched?
purplezr2
Central MN
Excellent question!
Agree not switch, used for the switches internal electronics.
Believe this is why there was a code change a few years ago requiring neutral at switching devices for smart switches etc.
johnre
Portland, OR
Don't keep us in suspense here.
I see four philips screws at the back corners; pull it apart and snap an image for us!
mm08822
Here's what the wiring could look like if the device had only 1 neutral terminal for running the electronics.....
Codyboy
S.E. TEXAS
Looks like it doesn't care about polarity.
An AC circuit itself is just a loop with a load completing the loop.
The neutral is does not have to be grounded for the circuit to work.
