Wi-Fi
gte718p
It is a knock off of the Ubiquiti bridge. Even trying to make the logo look like the Ubiquiti logo.
I'm generally not in the sky is falling crowd tin foil hat crowd, but I am becoming more concerned about grey market products especially hardwired to my network. If you don't follow the cyber security world, there are becoming more and more cases of these devices becoming attack vectors, with because the product was defective by design, the manufacture skimped on security in the firmware, or there is no after sale hardware support so known vulnerabilities are not patched.
Spend the few extra dollars on TP-link or Ubiquiti. They are all made in China and all vulnerable to supply chain exploitation, but at least the big names have folks actively working on security.
nh_yota
Seacoast New Hampshire
While I agree that a wireless bridge is the "best" option, I just installed one of these TP-Link power line wifi extenders in my uncle's shop a couple months ago and it actually works better than I expected:
He has a small hunting cabin in rural upstate NY with a small wood-framed shop about 200' away. There is no viable cell phone service but the local phone company recently ran fiber down his dirt road so he signed up for 200 Mbps internet last summer. The wifi works great around the cabin but just isn't strong enough to reach the shop, so we discussed some options.
Wifi at the shop is more of a convenience for him and allows him to use his cell phone and do a little bit of Roku streaming, so he didn't want to bother with trenching a cable or setting up a wireless bridge. The shop is powered by a 240v line from the house and there isn't much interference up there in the woods. We figured we could try the power line bridge first and if it didn't work then no big deal.
I set it up when I was up there on Thanksgiving weekend and was pleasantly surprised with the results. I configured it to use the same SSID as the router in the cabin so our cell phones hand off seamlessly between the cabin and the shop.
I think the power line extender has a throughput limit of around 300 Mbps which is faster than his internet speed so it's not a bottleneck.
sz0k30
I have a typical 30x40 pole barn about 75' from my house. Range extender on outside of house nearest pole barn [Netgear 5 ext]. Signal inside is barely adequate in summer with garage doors open. Much worse in winter with doors closed. What is best way to get a good signal inside?
Get a "Wavelink". My pole barn is about 150 feet from the house and my WIFI is on the opposite side of the house. Has to go thru walls and no direct line of sight. It works!
BLUE72CAMARO
IL
Ive been running a tp-link bridge to my buildings with a tp-link access point mounted in the walk way between them for 3 years now and 0 issues with it. I was in a similar situation where trenching in a line was a no go due to driveway and patios.
Gutman
ENC
Will those type bridges be affected too much if there are trees in between or will it punch through?
Depends on if you're talking a forest or some trees, I think.
Ubiquiti wireless bridge (Nanostation Loco M with a wireless router in the shop) works well for me, and I'm running at about 280' and going through? a big magnolia, a big oak, a couple **** trees, and some brush, but I've experienced no issues. Could not get direct clear LoS between the buildings without major tree removal; hard no from SWMBO.
I could see my signal downstream, roughly in the beam, at the neighbors house, though the woods about 1/4 mile away, but I've not experimented with whether that signal was usable. You can adjust the transmit power level and they claim km type ranges. I dialed the power level down a bit from the factory setting, and it works well for me.
I initially thought trench, conduit, and Cat 6 was my plan. Even did the trench part (and still have the conduit) when I rented a trencher for some other electrical work on my property, however, my trench ended up meandering much greater due to conflict between a septic field, major trees and roots, some unlocated water supply lines, fill rock, and other miscellaneous obstacles. Sort of a lazy S. That and a water table at about 2 feet; thought I clipped an unlocated water line or septic when trenching. Fun times when you're trenching and it starts throwing fill rock, mud, and water (and my water shut off is also 1/4 mile away, by that neighbor's house). Filling the unused trench well after digging was less fun.
During the COVID fiasco, my BiL (IT Exec from Austin) and family relocated here he upgraded my IT infrastructure so they could work remotely from here. He moved me to a wireless ORBI mesh system for in the house and we tried that and then several range extenders with no success to the shop. I've got one that pushes out the backside of the house to the dock and it works there at about 320' but it's clear LoS.
He then pointed me to Ubiquiti.
The things I like best: On a loss of power, it all starts up on its own with no intervention, and because I set the home and shop wireless for the same SSID login, going between house and shop with laptop and phone are seamless. I've been running my setup for about 4 years and have not had to do anything. Though, as I think about it, I should probably go and blow out the wireless router in the shop.
The downside: SWMBO thinks I've relocated to the shop because I can do so much more from there.
Codyboy
S.E. TEXAS
Ok the reason I ask is because yes it is very wooded and I'll need wireless up at the gate which is almost a 1/4 mile.
I'm guessing these are a directional beam setup.
I also have read some on an omnidirectional setup outside antenna for wifi.
probably not gonna work
yes they are line of sight and directional
