Wide pattern air gun?
Indy125
Northern NJ
Hi All,
I use my air gun at work to blow off parts that where just cleaned and rinsed with water. Right now, it's a standard air gun, with a pinpoint target, even when moving as far a way as possible while still being effective. I was wondering if there is an airgun that has a fan, or wide type of pattern for blowing air? I'm picturing a pattern like a wide power washer tip. I would like to use this air gun to reduce the time I spend blowing parts off. Thanks for any and all suggestions!!
Like this but air instead of water :)
PCustoms
VT
scooby074
Nova Scotia
Air knife. At a plant I worked at there were several mounted over conveyors to "wipe" water off product as it passed underneath after coming out of a bath. I think the ones in the plant were made by Silvent? Heres a similar tip mounted on a blowgun. https://guardair.com/products/ultra-quietforce-safety-air-gun?variant=11617483358252 They create a thin blade of air that acts like a squegee. If youve ever tried one of those Dyson hand dryers you put your hands inside then retract, its sort of like that.
dnschmidt
Phoenix, AZ
Well, a Walcom waterborne paint paint dryer is exactly that. A fan shaped blow gun with a valve build into it. They cost over $50 but for drying waterborne basecoat they are the nuts.
