Wiha 32800 Master Insulated Tool Set NEW
cjn1014
Price
1200
Brand New in Box, never opened.
Free Shipping Lower 48
Details
Each Tool Has Dedicated Position For Easy Storage & Retrievals
Lockable Rolling Water Tight Case Keeps Your Tools Secure
Custom Molded Rolling Carry Case - Job Site Solution
Professional Quality Tools - Made By Wiha
Insulation 10,000 Volt Tested & 1000 Volt Rated
All Wiha Insulated Tools Individually Tested For Insulation Integrity
Pliers Included
6.3" Long Nose Pliers
6.3" Diagonal Cutters
8.0" Long Nose Pliers
8.0" High Leverage Cutters
6.3" Bent Nose Pliers
6.3" Cable Cutters
6.3" Long Flat Nose Pliers
6.3" Stripping Pliers
9.0" Combo Pliers/Crimpers
8.0" Adjustable Wrench
Slotted Screwdrivers
Insulated Slotted 2.5mm
Insulated Slotted 3.0mm
Insulated Slotted 3.5mm
Insulated Slotted 4.0mm
Insulated Slotted 4.5mm
Insulated Slotted 5.5mm
Insulated Slotted 6.0mm
Insulated Slotted 6.5mm
Insulated Slotted 8.0mm
Insulated Slotted 10.0mm
Phillips Screwdrivers
Insulated Phillips #0
Insulated Phillips #1
Insulated Phillips #2
Insulated Phillips #3
Inch Nut Drivers
Insulated Nut Driver 7/32"
Insulated Nut Driver 1/4"
Insulated Nut Driver 5/16"
Insulated Nut Driver 3/8"
Insulated Nut Driver 7/16"
Metric Nut Drivers
Insulated Nut Driver 5.0mm
Insulated Nut Driver 5.5mm
Insulated Nut Driver 6.0mm
Insulated Nut Driver 7.0mm
Insulated Nut Driver 8.0mm
Insulated Nut Driver 10.0mm
Insulated Nut Driver 13.0mm
Hex Inch T-Handles
Insulated T-handle Hex 5/32"
Insulated T-handle Hex 3/16"
Insulated T-handle Hex 7/32"
Insulated T-handle Hex 1/4"
Insulated T-handle Hex 5/16"
Insulated T-handle Hex 3/8"
Hex Metric T-Handles
Insulated T-handle Hex 4.0mm
Insulated T-handle Hex 5.0mm
Insulated T-handle Hex 6.0mm
Insulated T-handle Hex 8.0mm
Torx Screwdrivers
Insulated Torx T6
Insulated Torx T7
Insulated Torx T8
Insulated Torx T9
Insulated Torx T10
Insulated Torx T15
Insulated Torx T20
Insulated Torx T25
Insulated Torx T30
Square Screwdrivers
Insulated Square #1
Insulated Square #2
Terminal Block Screwdrivers
Insulated Slt/Ph Terminal #1
Insulated Slt/Ph Terminal #2
Inch Sockets
Insulated Socket 1/2"
Insulated Socket 9/16"
Insulated Socket 5/8"
Insulated Socket 11/16"
Insulated Socket 3/4"
Insulated Socket 13/16"
Insulated Socket 7/8"
Metric Sockets
Insulated Socket 13mm
Insulated Socket 14mm
Insulated Socket 15mm
Insulated Socket 17mm
Insulated Socket 19mm
Insulated Socket 20mm
Insulated Socket 22mm
Accessories
Insulated Ratchet 3/8" Drive
Insulated 4.9" Extension 3/8" Dr.
Insulated L-key 10mm
Insulated L-key 1/2"
Single Pole Voltage Detector-110V to 250V
Insulated Cable Knife 50mm
2 Meter Ruler In/MM
